deere 4110 won't start
/ deere 4110 won't start #1
flagman
webster
john deere 4110
I have a john deere compact 4110. will not start. I jumped the starter to get it to my garage. I had the starter checked OK . I then replaced the glow relay. checked the fuse. Was this relay the right relay? Is there another relay? What am I missing. battery is fine
/ deere 4110 won't start #2
If I read your post right, it started when you jumped it. If so, the first place I would check is both battery cables--AT BOTH ENDS!! Make sure they are clean and tight.
I found a 40 amp fuse blown. At that point with that size fuse going I broke down and called the jd dealer to come fix it. They might be able to get to it next week. I guess ill hay the lawn instead of mowing
Well they haven't picked it up yet. they estimate not being able to look at it until the end of the week. I will keep you all posted:confused:
