Deere 4110 3-point hitch problem
   / Deere 4110 3-point hitch problem #1
4runner
Bronze Member
WNY
JD 322, JD 4110
My 4110's 3-pt hitch lever is acting up. It had been binding, but with some effort, I could always get it to move the full range. Today, I looked at the level and it was a bit twisted. I straightened it, (aka bent it back) but now it moves to the highest position ok but will not go lower than "5". If you look at the attached picture, the photo on the left shows the lever while it is at the "8" position, and "pt A" shows a bolt head in a slot. In the photo on the right, I moved the the lever as far down as it will go and it interferes with the bolt head at "pt B". In a way, it seems like the bolt may be intended to be a stop for the lever. But since the bolt is on a slot, and is as far forward as it can be, I am thinking it something is not right. I could bend the lever to clear the bolt head, but that doesn't seem right either.
Anyone have any thoughts? Thanks.
Bob
For what it's worth, I was able to bend the lever where the interference was and it appears to work.
2015 FORD F750 26FT BOX TRUCK (A51219)
2015 FORD F750...
2016 Ford Explorer AWD SUV (A48082)
2016 Ford Explorer...
2022 John Deere 8RX410 Track Tractor (A50657)
2022 John Deere...
2022 Forest River Cherokee Grey Wolf 26BRB Patriotic Edition 32ft. T/A Travel Trailer (A48082)
2022 Forest River...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A51039)
Kubota 24in Quick...
(INOP) CATERPILLAR TL943 TELESCOPIC FORKLIFT (A50459)
(INOP) CATERPILLAR...
