Deere 4100 - Is there a way to check indicator lights?
   / Deere 4100 - Is there a way to check indicator lights? #1
RMJ22
Deere 4100, Deere 445, Deere 757 Z-Trak
In particular I want to make sure my temperature light in the dash works and will come on if my engine were to overheat. It does not come on briefly, like some lights do when you turn on the key, to let you know its working. How can I test it to make sure it is indeed functioning. FYI - my tachometer is not working, so I'm just wanting to check other lights. I know my hazard/flasher light and pto indicator lights do work.
And I would like to periodically check my engine temp with an infrared thermometer. What would be ideal operating temperatures and where should I point the temp gun?
Thanks in advance!
2018 Nissan Pathfinder SUV (A50324)
2018 Nissan...
Stainless Steel 1" Spool (A49461)
Stainless Steel 1"...
(4) 320 x 90 R50 Tires and Rims (A50514)
(4) 320 x 90 R50...
(INOPERABLE) MAROOKA (A50854)
(INOPERABLE)...
CRESCENT  MANIFOLD TRAILER (A50854)
CRESCENT MANIFOLD...
1996 Fertilizer Tender Trailer (A50514)
1996 Fertilizer...
