Deere 310C TLB Price
   / Deere 310C TLB Price #1
Snowman9000
Grundy County, IL
JD 755
I am looking at a 310C 2WD with cab. Everything is straight and in good condition. Exterior has been repainted. Motor and hydraulics have all original paint and dust and have not been cleaned, but look very good. No leaks. Oil and antifreeze are new so hard to tell anything there. No obvious hydraulic leaks. Fairly tight joints. Front tires are about worn out. Rear tires good. 24" bucket. 3200 hours. Starts and runs good, no smoke. Brakes take a mighty step to keep from moving in idle, but I have noticed that on other machines.
This unit will be auctioned tomorrow. Any guesses on value?
Here's a photo of it.
   / Deere 310C TLB Price #3
Snowman.
Did you know the year of 310C.
Maybe this will help.
310C,1985,65hp diesel,5.770hrs,rops cap w/heater,fwd,kept up,asking $19,900.oo
310A,1979,58hp diesel,2wd,1.197hrs,rops cab w/heat,very clean,asking $9,950.oo
Hope this gives you a ball park figure,and watch and listen to others as they look at the unit before bidding takes place...good luck.
Thomas..NH /w3tcompact/icons/wink.gif
No, the year is not listed. I too have seen [ads for] older 310A's with cabs around $10,000. If I thought they'd be decent, I'd skip bidding on the "C" tomorrow and keep looking at an "A". However, the machine seems pretty good. We are thinking it should go in the $14-18K range. Not sure we want to be buying an auction unit at the high end of that range.
-Don M aka Snowman9000
   / Deere 310C TLB Price #5
Okay..you got to tell me Snowman,how did you make out at the auction..did you purchase the 310C /w3tcompact/icons/smile.gif and what was the final bid.
Short answer: We bought it!!! :)
Longer answer:
I read another post in this forum, recommending to check auction results through machinerytrader.com. I did that and figured out the year as 1989 through the serial numbers listed. And there were 57 auction results for 310C's from 1988 to 1990, and they calculated the average price as $13,900. Average "For Sale" Ad price was $20,400. After reviewing the various listings, I went into work and told my partner my prediction of $11,000 to $15,000. I would highly recommend that site for preparing to bid at an auction.
We bought it at $13,000. We are happy.
   / Deere 310C TLB Price #7
Glad for you and your partner. /w3tcompact/icons/smile.gif/w3tcompact/icons/cool.gif
So what else did you buy??/w3tcompact/icons/wink.gif
We didn't buy anything else.
That will keep us busy for a while.
-Don
   / Deere 310C TLB Price #9
Kenny
I would say around 18k-20k, it also depends on the age and amount of hours on it. good luck.
2012 Manitex 50110SHL 50-Ton Boom Crane Truck (A53117)
2012 Manitex...
Pallet of Miscellaneous Heaters (A52384)
Pallet of...
2012 Ford F-350 4x4 9FT Knapheide Flatbed Truck (A51691)
2012 Ford F-350...
2010 Ford Edge Limited AWD SUV (A51694)
2010 Ford Edge...
UNUSED 20PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 20PCS...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
