Deere 3043 D
   / Deere 3043 D #1
forestcreature1
earth, more or less
Adding to the Deere herd...
3043 D, R1, rear SCVs, loaded rears [washer fluid & iron weights].
There is NO PROOF that I went through Hardee's on the test drive. IMG_5502.jpg
   / Deere 3043 D #4
It’s a D, which means manual transmission. The one near the seat is the shifter I assume.
   / Deere 3043 D #5
Where do you see two joysticks?
In the OP's photo, there's one on the FEL pillar and there's the standard JD 'floor mounted' one.
Perhaps it's because JD has contracted a separate company to build their FELs and that's the way they build them so that they can be used with tractors that don't have a 'standard' (already included) joystick?
Here in Aus, I know that my JD 300CX FEL has been replaced with an Aus-built "Challenger" FEL. (probably due to some Aus regulation/requirement)
   / Deere 3043 D #6
In the D series, that is the gear shift on the right where you are thinking it is a joy stick. What dodge man said.
   / Deere 3043 D
Yes, thank you everyone.
It is the gear shift lever [four gears].
The FOR/REV lever is on the left hand dashboard [and it goes 1 mph faster in REVERSE than it does forward] ;)
Deere's website has detailed pics on all of the controls.
The economy series [3E / 3D] use the same loader with the integrated [to the loader] joystick.
This practice was common for open station machines that were 'universal use' vs dedicate tractor/loader/backhoe [TLB] across all of the brands.
Loaders for my 2017 Massey Ferguson 2605H are made that way.
Deere changes the numbers once in a while, which looks more like marketing than engineering.
(both for loaders & machines)
The "bucket-end" of the loader mounts the same things as the 3R series (and probably more, my experience is with the 3 series compacts with this size loader).
Let me know if you have more questions, there isn't very much "owner" info on this machine out there yet.
   / Deere 3043 D
Dealer will park it in the drive Friday [boss is letting me work from home that day so I can sign for it] :)
   / Deere 3043 D #10
There is a monroe county in Wisconsin... or are you elsewhere in a monroe county..??
Hope to see more pics... and that you will be happy with this tractor.. what is the primary use for it?
JMR tree boom attachment (A53421)
JMR tree boom...
2019 Komatsu D51PXi-24 Crawler Tractor Dozer (A51691)
2019 Komatsu...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A53473)
2012 JOHN DEERE...
2018 Ford F-250 Reading Enclosed Service Truck (A53422)
2018 Ford F-250...
2005 Dodge Caravan Van (A51694)
2005 Dodge Caravan...
2024 CFMoto Cforce 600 4x4 ATV (A51694)
2024 CFMoto Cforce...
