Deere 3043 D
   / Deere 3043 D #1
forestcreature1
earth, more or less
Adding to the Deere herd...
3043 D, R1, rear SCVs, loaded rears [washer fluid & iron weights].
There is NO PROOF that I went through Hardee's on the test drive. IMG_5502.jpg
   / Deere 3043 D #4
It’s a D, which means manual transmission. The one near the seat is the shifter I assume.
   / Deere 3043 D #5
Where do you see two joysticks?
In the OP's photo, there's one on the FEL pillar and there's the standard JD 'floor mounted' one.
Perhaps it's because JD has contracted a separate company to build their FELs and that's the way they build them so that they can be used with tractors that don't have a 'standard' (already included) joystick?
Here in Aus, I know that my JD 300CX FEL has been replaced with an Aus-built "Challenger" FEL. (probably due to some Aus regulation/requirement)
   / Deere 3043 D #6
In the D series, that is the gear shift on the right where you are thinking it is a joy stick. What dodge man said.
   / Deere 3043 D
Yes, thank you everyone.
It is the gear shift lever [four gears].
The FOR/REV lever is on the left hand dashboard [and it goes 1 mph faster in REVERSE than it does forward] ;)
Deere's website has detailed pics on all of the controls.
The economy series [3E / 3D] use the same loader with the integrated [to the loader] joystick.
This practice was common for open station machines that were 'universal use' vs dedicate tractor/loader/backhoe [TLB] across all of the brands.
Loaders for my 2017 Massey Ferguson 2605H are made that way.
Deere changes the numbers once in a while, which looks more like marketing than engineering.
(both for loaders & machines)
The "bucket-end" of the loader mounts the same things as the 3R series (and probably more, my experience is with the 3 series compacts with this size loader).
Let me know if you have more questions, there isn't very much "owner" info on this machine out there yet.
   / Deere 3043 D
Dealer will park it in the drive Friday [boss is letting me work from home that day so I can sign for it] :)
   / Deere 3043 D #10
There is a monroe county in Wisconsin... or are you elsewhere in a monroe county..??
Hope to see more pics... and that you will be happy with this tractor.. what is the primary use for it?
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51692)
2023 Stryker...
2005 IH 7600 t/a Dump Truck (A52384)
2005 IH 7600 t/a...
2010 Ford Fusion Sedan (A51694)
2010 Ford Fusion...
2015 Ford F-450 Bucket Truck (A53117)
2015 Ford F-450...
2008 Chevrolet Uplander (A51694)
2008 Chevrolet...
2025 K1912 UNUSED Metal Livestock Shed (A53117)
2025 K1912 UNUSED...
