Deere 25AFlail Mower Bearings
   / Deere 25AFlail Mower Bearings #1
OFarrell
NH Workmaster 60
I've got an older 25A flail mower that needs roller bearings and is probably close to needing drum bearings. The dealer is telling me the only bearings available are the hex roller bearings for $150 each. Anyone know if aftermarket bearings are available? I have not seen anything in my brief searching.
   / Deere 25AFlail Mower Bearings #2
Look at the John Deere Parts website. Here is a link to the page showing the rotor and bearings. John Deere Parts Catalog
The rotor bearings are $27 each and the roller bearings are $13 each.
   / Deere 25AFlail Mower Bearings #3
How close to a fairly large city? There are bearing/industrial supply houses that can virtually match up any thing. Back in my industrial construction days we ran into match up problems on many old non-supported bearings and seals. Not a thing you can buy on the internet unless you have manufacturer and part #
Ron
I finally got around to buying bearings. My mower has the hex style roller. How do I get the end cap off without damaging it? Do I need to drop the roller out of the mower to do it?
   / Deere 25AFlail Mower Bearings #5
The end of the roller shaft tends to get damaged from catching rocks, stumps, etc... I had to touch up the end of mine with a grinder to smooth it out enough that the hex retainer would slide off. I might have heated it up, too. The bearings on mine were trash, too, so heating wasn't really an issue. It took a bit of grinding, some heat, and a bit of persuasion but they came off. I did not remove my entire roller.
I put the flail on my tractor, lifted it all the way up, put jack stands and wood cribbing under it so it couldn't move if the hydraulics failed. I blocked the tires on the tractor so it couldn't roll. Then I used more jack stands to support the roller as I worked on removing the bearings. If I recall, it probably took me about an hour and a half to replace them. Most of that was getting the end caps off without totally destroying them.
   / Deere 25AFlail Mower Bearings #7
Mine don't look awful, just rusted on. I'm thinking about cutting them off and switching to a two piece hex collar like this. https://www.google.com/url?sa=t&sou...FjABegQIBRAJ&usg=AOvVaw1dWbBHjAXxf8KsmaRPh_yR
We will see how mangled it gets I don't think it's going to come off without the assistance of an air hammer, grinder or rosebud.
This might be a dumb question, but you did remove the set screw, right? If I remember right, mine had a single set screw holding it on and once the shaft was squared up/ground clean it came off easily.
I removed a roll pin from each side. Where is the set screw?
   / Deere 25AFlail Mower Bearings #9
Maybe it was a roll pin, haha, I can’t remember, it’s been a while. I’ll have to look when I get home.
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
2010 PETERBILT 387 TANDEM AXLE SLEEPER TRUCK (A52576)
2010 PETERBILT 387...
2016 MACK CXU613 DAY CAB (A52576)
2016 MACK CXU613...
2006 INGERSOLL RAND AIR COMPRESSOR (A52472)
2006 INGERSOLL...
2007 International 4300 Box Truck, VIN # 1HTMMAAL27H513415 (A51572)
2007 International...
2018 TAKEUCHI TL12V-2 SKID STEER (A51242)
2018 TAKEUCHI...
