Deere 246 Rotary Broom
   / Deere 246 Rotary Broom #1
Colledge
Shermansdale,PA
John Deere 455
I am trying to repurpose a Deere 246 Rotary broom to my Deere 455 without spending more than I paid for the broom. I am trying to convert from PTO driven to hydraulic or electric/hydraulic motor to operate the broom. Has anybody been down this path ? Any suggestions would be appreciated !!!
   / Deere 246 Rotary Broom #2
Is your 455 set up to operate a hydraulic motor driven implement? to try and figure a motor size you will need to know the hydraulic flow rate available as well as the pressure. This can be used to calculate the hydraulic motor RPM and torque. I suspect you may be disappointed with the operation of this broom using hydraulics Vs PTO.
It only has the factory hydraulics. I though I might be able to get away with it since there are Deere hydraulically driven rototillers ? But then running at 540 RPMs versus 2000 RPMs is a substantial difference.
2001 NEWMAR 45FT TANDEM RV WITH 2 SLIDE OUTS (A51222)
2001 NEWMAR 45FT...
2016 Ford F-150 Crew Cab Pickup Truck (A50323)
2016 Ford F-150...
197359 (A50458)
197359 (A50458)
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2003 Ford F-650 Flatbed Truck, VIN # 3FDNW65243MB03484 (A48836)
2003 Ford F-650...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
