Deere 246 Rotary Broom
   / Deere 246 Rotary Broom #1
Colledge
Shermansdale,PA
John Deere 455
I am trying to repurpose a Deere 246 Rotary broom to my Deere 455 without spending more than I paid for the broom. I am trying to convert from PTO driven to hydraulic or electric/hydraulic motor to operate the broom. Has anybody been down this path ? Any suggestions would be appreciated !!!
   / Deere 246 Rotary Broom #2
Is your 455 set up to operate a hydraulic motor driven implement? to try and figure a motor size you will need to know the hydraulic flow rate available as well as the pressure. This can be used to calculate the hydraulic motor RPM and torque. I suspect you may be disappointed with the operation of this broom using hydraulics Vs PTO.
It only has the factory hydraulics. I though I might be able to get away with it since there are Deere hydraulically driven rototillers ? But then running at 540 RPMs versus 2000 RPMs is a substantial difference.
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
2019 Club Car Carryall 1700 4x4 Diesel Utility Cart (A48082)
2019 Club Car...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
1999 INTERNATIONAL PAYSTAR 5000 TANDEM AXLE DUMP TRUCK (A51222)
1999 INTERNATIONAL...
2005 International 4300 Heil Dump Truck (A50323)
2005 International...
2005 MACK GRANITE GU713 DAY CAB (A51222)
2005 MACK GRANITE...
