Deere 2305 Vs. Kubot B7600 - B2630 compact tractor
   / Deere 2305 Vs. Kubot B7600 - B2630 compact tractor #1
havrilj
PA, Mercer
This comming spring I in tend to purchase a compact tractor... I have around 4 acres of field/grass to cut.. plus I need to do some front end loading ... I NEED 4WD beacuse it gets pretty soggy in some areas... I have around 600 ft of creek that has misc. scrap trees that need to be pulled out because they are blocking the flow of the creek. my father likes the John Deere 2305 and I am leaning towards the kubota B7600 or the new B2630. I want to make the best decision possible. Please help... when I buy I do intend of purchasing the FEL and Backhoe. please point me in the right direction. The reason behind staying on these two particular brands is that the dealership that sells them is only 2 miles away!
As a side note I want the tractor to be able to have the mid mower deck on when the FEL and backhoe are on. I do not want to have to keep taking the implements on and off all the time.
   / Deere 2305 Vs. Kubot B7600 - B2630 compact tractor #2
Welcome to TBN. You may want to fill out your profile -- at least where you are located because many answers to questions depend on your location.
Just an FYI, TBN frowns upon Cross Posting.
   / Deere 2305 Vs. Kubot B7600 - B2630 compact tractor #3
Wondering why you limited your self to those 2-3 particular tractors?
   / Deere 2305 Vs. Kubot B7600 - B2630 compact tractor #4
There's a ground clearance difference between the Kubota tractors and the 2305, if it's like the 2210. The 4010 or 4110 are more equal in ground clearance to the Kubota ones you're looking at. Think the 4110 is being replaced by the 2520. There's a posting with a picture of it. I may have the numbering not quite right.
Ralph
What did you have in mind?
   / Deere 2305 Vs. Kubot B7600 - B2630 compact tractor #6
Well, there's the NH line, the Simplicity, the MF and Kioti. Just to name a few.
   / Deere 2305 Vs. Kubot B7600 - B2630 compact tractor #7
</font><font color="blue" class="small">(
As a side note I want the tractor to be able to have the mid mower deck on when the FEL and backhoe are on. I do not want to have to keep taking the implements on and off all the time. )</font>
I think you will change your mind soon about having all the implements on all the time. The backhow and FEL while mowing will become a major nuisance and the weight of everything won't be good while mowing.
i understand that ... i mean i dont want to have to remove the mid mower deck... taking the FEL on and off as well as the Backhoe is not a problem... i do not want to cut the grass with the FEL and backhoe on ... but am i going to be able to have all three implements on at the same time... ie. trailering?
   / Deere 2305 Vs. Kubot B7600 - B2630 compact tractor #9
i agree with NATURAL having all the attachents on at the same time can e PIA the MMM can be especially tough when doing work where ground clearence is critical.plus the BH on the back when not needed just adds weight and can be a problem when working in close quarters.
   / Deere 2305 Vs. Kubot B7600 - B2630 compact tractor #10
<font color="blue"> but am i going to be able to have all three implements on at the same time... ie. trailering? </font>
You can have all 3 attachment on a B2630. The MMM must be pinned up before BH is installed. You do not mention what size MMM you are looking at. When I purchased my B2910 with 72" MMM I had to look for a wider trailer. With discharge chute up it has only a couple of inches clearance on my 84" wide trailer deck.
Pallet of (11) 10 Lug Misc Wheels (A48837)
Pallet of (11) 10...
1 TON CHERRY PICKER (A48992)
1 TON CHERRY...
14ft Flatbed Truck Body (A48081)
14ft Flatbed Truck...
2018 Hyundai Sonata Sedan (A48082)
2018 Hyundai...
Skid Steer Quick Attach 3pt Hitch (A47371)
Skid Steer Quick...
(2) New/Unused Welding Helmets (A48837)
(2) New/Unused...
