deere 214t baler
/ deere 214t baler #1
donais
ramona ca
mf 1547
i got a new bushing for the shear bolt on the flywheel. how does it come out? press it, beat it? take the flywheel off or?? i guess i ordered a new one so might as well change it
/ deere 214t baler #2
Big hammer & elbow grease with flywheel attached to baler
/ deere 214t baler #3
Are you speaking of the 1/4" bolt that holds the flywheel in position to the shaft ??? If so, push it out from the front with a new bolt... In the ear there should be an indent for the bolt head.... On my 14T that is the way it is put together.....
/ deere 214t baler
its the bushing that the bolt goes in.the bushing is has 1/4 inch hole about 1 inch od. i was wondering if i need to pull the bushing out or just beat it through. so far im gonna use the hammer elbow grease method.
/ deere 214t baler #5
As long as the shear bolt arm that's splined to the gearbox is not blocking the travel of the bushing while attempting to remove the bushing can be driven towards the baler.
/ deere 214t baler
oh cool thanks.
/ deere 214t baler #7
Here's you a parts breakdown. Parts key #11 is the shear pin arm I was referring to
/ deere 214t baler
im changing # 7
/ deere 214t baler #9
Yes #7 is the replaceable bushing that requires a big hammer.
/ deere 214t baler #10
im changing # 7
Where did you get that bushing? Or, what size is it? Does it have the hex shape in it to hold the bolt head? Mine seems to be stripped.
/ deere 214t baler #11
Your friendly JD dealer. BP14087 Bushing ADD 24.55 USD
/ deere 214t baler
I ordered it form aa equipment in san diego. but as jim said use that p/n and go to jd dealer
JLG 20MVL MANLIFT (A58214)
JLG 20MVL MANLIFT...
KUBOTA SVL75 ENCLOSED CAB (A52706)
KUBOTA SVL75...
Carry-On 6'x8' Trailer (A53316)
Carry-On 6'x8'...
2002 Allmand Night-Lite Pro Towable Light Tower (A56857)
2002 Allmand...
Bobcat T590 (A60462)
2013 COACHMEN CATALINA TRAVEL TRAILER (A55745)
2013 COACHMEN...
