Deere 110 TLB help
   / Deere 110 TLB help #1
crimedog325
woodbury, Ct
JD 110TLB
Just bought a new to me 2003 Deere 110 tlb. unfortunately its first use was to bury my pup. It worked great and had plenty of hydraulic power(fel and backhoe) . I have put about 10 hrs on it and it has been losing power pretty quickly. engine rpm seems fine 2300 and seems like it drives pretty well , which I believe is also run by main pump. Fluids all look good and filters less than a year old. Any ideas on what can cause this issue? I have checked linkages for binding and everything seems good. The three point hitch lever(rockshaft) is all the way forward and seems to be fully traveling,(when checked on the rear of the tractor). I know there is a switch that is supposed to deactivated the rockshaft when the backhoe is attached but I have noticed that it still moves. I am not sure if that can be an issue even though the lever is in the off position. Any ideas would be greatly appreciated. I was hoping to get more than two days use before having issues :(
   / Deere 110 TLB help #2
Sorry to hear about the issues. could you be more descriptive about losing power? the rockshaft should not move if the backhoe is on. If it moved far enough, I am sure it would catch on something, and likely would not be good. I know the switch is more prone to read backhoe attached (when it is off) then backhoe off (when it is actually on) but a wiring issue could give it the wrong reading. anyway from what I remember that switch directs a few gpm (from an aux pump) to either the 'hoe, or the hoe and loader, but it would only be like 10-20ish %
2013 International WorkStar 7400 4x4 Altec DMA71 Insulated Digger Derrick Truck (A48081)
2013 International...
Heavy Duty Forklift Plate and Forks (A50860)
Heavy Duty...
2020 Chevrolet Express 2500 Animal Control Cargo Van (A48081)
2020 Chevrolet...
Craftsman LT2000 42in. Riding Mower (A49346)
Craftsman LT2000...
2018 Skyjack SJ1056TH 10,000lb 4x4 Rough Terrain Telehandler (A49461)
2018 Skyjack...
2014 Ford Escape SE SUV (A48082)
2014 Ford Escape...
