Deere 1070 with bent MFWD shaft
   / Deere 1070 with bent MFWD shaft #1
ericrj
Haymarket, VA
Deere 1070
I've got a Deere 1070 w/MFWD, and I accidently high centered the tractor on a log and bent the FWD shaft. If I roll the shaft on a flat surface, it looks to be bent about 3/8". It seems to work fine, but I'm worried that I'll quickly wear out the bearings if I leave it as is. Is this likely?...if so, can I straighten the shaft myself? Is there an easy way to do this, and how straight do I need to get it.
   / Deere 1070 with bent MFWD shaft #2
I'd put a floor jack under it and push up until its back to shape. This is the drive shaft inside a thin F/A tube, right? You'll need to straighten the dent in the tube, too, eh?
My 1070 tube/shield had some fracture issues and I easily repaired it. Stick a wide wooden broom handle down it and hammer the dent out.
2017 Ford F-450 XL (A50120)
2017 Ford F-450 XL...
2024 Bintelli Activ-EV Pulse (A50324)
2024 Bintelli...
2006 Toyota Highlander SUV (A50324)
2006 Toyota...
2019 Nissan Sentra Sedan (A50324)
2019 Nissan Sentra...
2015 Peterbilt 320 EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
