Deere 1023E, 1025R, and 2025R recall
   / Deere 1023E, 1025R, and 2025R recall #11
I went out and checked my JD 2025r and the bell crank that is the problem on mine is cracked so it’s really not safe to use. If it breaks, you end up with no brakes. I called the dealer and they knew less about the recall than I did. The recall letter lists a date of October 25 for when the improvement program will be released for mine. I took a pic of mine and circle the crack in yellow.
   / Deere 1023E, 1025R, and 2025R recall #13
Edit: Part number LVU31387 (found it, thanks)
Most people using their tractors seldom use the brake pedal as the HST will stop the tractor, however it is a safety device in sometimes critical situations.
It looks to be LVU31387
   / Deere 1023E, 1025R, and 2025R recall #16
Looks like an easy fix to replace that cracked piece.
It is easy to replace I’ve read, the problem is the new part would break again. The way I understand the recall will install a better part.
Here is a good video.
   / Deere 1023E, 1025R, and 2025R recall #18
Just JD cutting corners to save profit again. Instead of two ounces of metal they use a half ounce. Then pat each other on the back gaining more profit on the entry level tractors. Looks like it came back and bit them. :oops:
The only recall for vehicle that I know the back story is supplier cut corners , didn’t meet specifications and falsified data. Supplier went out of business
1 Ton Mini Excavator Hydraulic Thumb (A57454)
1 Ton Mini...
2013 BMW X5 AWD SUV (A56859)
2013 BMW X5 AWD...
CFG Industry H12R Mini Excavator (A57149)
CFG Industry H12R...
yellow ball Trailer (A56859)
yellow ball...
2016 Kubota MX5200 (A57148)
2016 Kubota MX5200...
2005 Peterbilt 387 with Wet Kit (A56438)
2005 Peterbilt 387...
