Deer690b
/ Deer690b #1
Newtotrackhoe
Dayton,Tn
Deer690b
Have a relic, using on the farm pretty solid unit . Problem is a bad boom valv. its not just the seals have replaced them several times. The internal valve walls are worn creating slop in the piston movement. Deer does not supply the assembly. Have previously purchased a used unit lasted about a week, blowed by seals again, need a suggestion. Would prefer not the scrap metal option.
/ Deer690b #2
Take the part to a good machine shop and they should be able to bore and sleeve it back to original size.
/ Deer690b #3
Your best bet is to purchase a new valve. Forget that rebuilding thing. you can only replace o-rings, and they are not for pressure.
Look through these valves and find something suitable.
Surplus Center
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
2022 EZ-GO ELITE...
2015 Ford F-450 Crew Cab Dump Truck (A61573)
2015 Ford F-450...
iDrive TDS-2010H...
2015 Ford F550 4x4 with 37' Bucket (A62613)
2015 Ford F550 4x4...
CASE INTERNATIONAL 5240 TRACTOR (A63291)
CASE INTERNATIONAL...
