Deer690b
/ Deer690b #1
Newtotrackhoe
Dayton,Tn
Deer690b
Have a relic, using on the farm pretty solid unit . Problem is a bad boom valv. its not just the seals have replaced them several times. The internal valve walls are worn creating slop in the piston movement. Deer does not supply the assembly. Have previously purchased a used unit lasted about a week, blowed by seals again, need a suggestion. Would prefer not the scrap metal option.
/ Deer690b #2
Take the part to a good machine shop and they should be able to bore and sleeve it back to original size.
/ Deer690b #3
Your best bet is to purchase a new valve. Forget that rebuilding thing. you can only replace o-rings, and they are not for pressure.
Look through these valves and find something suitable.
Surplus Center
2007 Genie AWP-30S 30ft Manlift (A61572)
2007 Genie AWP-30S...
2025 HT360W Mini Walk-Behind Track Loader Skid Steer (A61572)
2025 HT360W Mini...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
2015 CATERPILLAR M313D MOBILE EXCAVATOR (A64279)
2015 CATERPILLAR...
2016 Eager Beaver 20XPT 27ft 24 Ton T/A Tag Trailer (A61573)
2016 Eager Beaver...
26ft. Truck Box Body (A61573)
26ft. Truck Box...
