Deer processing
   / Deer processing
36-37 degrees.
I didn't insulate the floor, (tile, on concrete, on fill dirt) which I suspect would help a LOT, but then, I only use it 10-15 days per year. Anything below 40 works fine for a cooler.
Construction is standard stud wall with 3 1/2" fiberglass insulation, plus 4" of foam board on top of that, and inside is thin white fiberglass panels. Door was a prehung unit off a used cooler, just screwed to wood opening.
ry%3D400
Good deal, That is excellent.
   / Deer processing #23
For years I've quartered and put it in a fridge. The fridge we use now is a commercial unit that has circulation fans to pull air over the coil so I place the deer inside of garbage bags to keep them from drying out.
But really, "quartering" isn't really what I do. Doesn't that term come from meat plant operations where they split an animal down the spline? That's just too much work. I wind up with 5 or 6 pieces: 2 shoulder, 2 hams, the backbone & loins, and sometimes the neck, depending on how big the deer is (sometimes we just leave the neck attached to the backbone).
2013 Chevrolet Caprice (A50324)
2013 Chevrolet...
2015 DODGE RAM...
2015 Ford Focus SE Sedan (A50324)
2015 Ford Focus SE...
2016 Ford F-150 Crew Cab Pickup Truck (A50323)
2016 Ford F-150...
2017 GEHL RS5-19 TELEHANDLER (A51242)
2017 GEHL RS5-19...
2019 HINO 155 16FT BOX TRUCK (A50505)
2019 HINO 155 16FT...
