Deer and your garden
   / Deer and your garden #31
Electric isn't as bad. You can take it down in the fall, unless you have a really big garden.
We had electric around a 40 acre garden and a butane gun blasting away at night. Plus we had a two story barn with windows and army cots up stairs. Spotlight shined real good out them windows.
   / Deer and your garden #32
Two years ago the garden was decimated by deer, for the most part they had left it alone for 20+ years.
Last year I installed an electric fence, with a solar charger. Worked great, best garden in history. It goes back up next week.
We have a dog, they ignore him. He's too old to give chase.
I done the same thing except my fencer is a Parmak 50 mile fencer with one wire around the garden about the height of the bottom of your pocket, the first night a deer walked into it and broke the wire and pulled it off of the insulator , from then on no more problems. They learn real quick.
   / Deer and your garden #33
47" field fence plus 4' of barbed wire on top. We also have to do something to keep the coons out. They will absolutely clean out a corn crop in one night. I trap them.
   / Deer and your garden #34
6' cattle fence with chicken wire L-shape along the bottom and ground with gravel covering up the chicken wire on the ground. Then mesh netting all around the outside to keep out the racoons.
   / Deer and your garden #35
Deer can jump a 12' fence easily. Seen it many times.
In this case the width is only 4 feet, so they see it as two fences and won't try it.
I said I had to go small with my garden, it's tiny.
   / Deer and your garden #36
Drink lots of coffee and piss high on surrounding tree trunks. Deer are afraid of big predators that are buzzed on caffeine. Don't know if it works but I don't have much problem with deer around the garden. :unsure:
   / Deer and your garden #37
Run an electric fence wire about 16" high off of the ground and the racoons will touch the wire and it stops them , if you have a few of the small metal pie pans hang them on the wire , animals are curious and they will touch the pans and they won't be back , even a small amount of bait hanging off of the wire the coons touch it and they get zapped. I have used electic for predator control for years and it works if done right.
I have never had to deal with the turkeys but I can stop racoons opossums and deer using electric...I can stop the problems at the chicken house with electric wire and fix it so you can leave the door open on the chicken house all night.
I have had racoons pull 1/4" hardware cloth wire apart and I put electric on the bottom of the cages and it stops them. I am using a 50 mile electric fencer on about 50 feet of wire that is just because I already had the electric fencer from when I had cattle.
UNUSED MOWERKING QUICK ATTACH ANGLE BROOM (A51244)
UNUSED MOWERKING...
Land Honor Skid Steer 3 pt Hitch Adapter (A50515)
Land Honor Skid...
1981 CASE 580D BACKHOE (A51242)
1981 CASE 580D...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51244)
(2) METAL SPOOLS...
UNUSED CFG INDUSTRIAL SSFM81 FORESTRY DRUM MULCHER (A51244)
UNUSED CFG...
TRUCKING INFO (A50774)
