Deep Post Hole
/ Deep Post Hole #1
kn6md
Yerington, NV
YM1601D
I have a YM1601D (no post hole digger) and am reviewing some plans that require 32 or so holes 18 inches wide and 58 inches deep. This seems like a stretch even if I were to use a 12 inch auger and widen the hole with an 18 inch auger. Would such a wide/deep post hole be even possible with a PHD on the 1601D?
Any thoughts would be appreciated.
Thanks,
Bill Vorhies
/ Deep Post Hole #2
The local Kubota dealer rents a Landpride post hole digger that has a 24" auger. I think there is such a thing as auger extentions that allow you the dig deeper than the normal 40"-48".
Chris
/ Deep Post Hole #3
Depending on the soil, it might be possible. Best to go with an 18" from the beginning. I have had little luck in widening holes. But the 3pt hitch only goes up and down about two feet vertically which means that you need removeable extentions every two feet or less. I don't often say this, but it sounds like a good reason to call in a commercial pier-drilling rig. Save the tractor for things that it is sized to do.
/ Deep Post Hole #4
I would have to agree on that.. It would be generating more work to do it with the tractor... terrible as it is to say...
Chris
/ Deep Post Hole #5
I purchased a posthole digger with a 12" auger for my YM2210 last summer to drill 26 holes that were 4 ft deep for deck construction around the house. Our soil is rocky clay here. Some of the holes were even drilled on sloped terrain. It takes some set up time and patience to accurately drill nice holes, but I believe it was worth it. I am certain that a rental would have cost as much or more than the purchase price of the digger. I now own it for future projects.
/ Deep Post Hole #6
Again.. deffinately not shying away from tractor mounted impliments..but a hand held motorized post hole digger will cost a little less, in most cases... however one for 18" holes will likely have to be one o fthe '2' man drills... may cost as much as a tractor mounted one.... just have to see if it is feasable.
When i installed my fence.. 525' of it was up against another fence, and the tractor was not available for it.. we used a hand held one with good results. ymmv.
Chris
/ Deep Post Hole
Thank you all for your replies. You have saved me a ton of aggravation. Based on your replies , I have requested that the plans be changed to a trench type foundation that my machine can handle. Looks like I will have to build a deck to get a post hole digger....
2018 FREIGHTLINER CASCADIA CA125 DC 6X4 T/A DAY CAB TRUCK TRACTOR (A59912)
2018 FREIGHTLINER...
2 Row Cole Planters w/Plates (A64119)
2 Row Cole...
2016 CATERPILLAR 308E2 CR EXCAVATOR (A64279)
2016 CATERPILLAR...
2012 Chevrolet Silverado 1500 Hybrid Crew Cab Pickup Truck (A61573)
2012 Chevrolet...
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
John Deere Worksite Pro RS72 (A64119)
John Deere...
