Deck Stand
/ Deck Stand #1
Vernonator
Iowa
'04 Cub Cadet GT 3235
Has anyone here fabricated a deck stand for their CC mower deck? I have a 3235 with a 54" deck. This thing is a beast to move around and stand up to clean/change blades. I would also like to stand it on edge for storage during the winter (I have a blade that I push snow with). Any suggestions, ideas, products out there?
Thanks
Mark
/ Deck Stand #2
Yeah, those are a beast. I have a hard enough time slinging around the 44" on my 2544! The 44" is just under 100lbs IIRC. Maybe you could grab a 2 wheeled hand truck from harbor freight (or the likes) to strap the deck to. Those trucks are cheap enough that you could dedicate one to your mower deck.
Joel
/ Deck Stand
**** JT!!! I had NEVER thought of that.....get one with big bouncy tires and that should do the trick!!!!!! Hmmmm may need to stop at TSC on the way home tonight!!!!!
/ Deck Stand #4
I'd probably bolt a wooden platform to the blade of the hand truck. The metal one will not only be small, but slippery and may scratch the paint easily.
Just create a wood platform, nail in some stops where you'd need them to prevent movement, then bolt that whole thing to the blade on the hand truck.
-Larry
/ Deck Stand
-Larry
TL - I was thinking the same thing - that I may need to fabricate some sort of add-on to the blade to make things more stable. Maybe even some sort of "out-rigger" to make it a bit more stable when I am cleaning/changing blades...but that should be fairly easy....
(7) DONALDSON P600676 AIR FILTERS (A64276)
(7) DONALDSON...
2022 CHEVROLET EQUINOX SUV (A66091)
2022 CHEVROLET...
2009 CHEVROLET 3500HD 4x4 PICKUP TRUCK (A59912)
2009 CHEVROLET...
2022 Landmaster EV (A64912)
2022 Landmaster EV...
QA Plate (A64912)
QA Plate (A64912)
ALLMAND MAXI-LITE II V (A67714)
ALLMAND MAXI-LITE...
