Comparison Decision time. L4701/L3901/L4060/L3560/B3350
   / Decision time. L4701/L3901/L4060/L3560/B3350 #61
I was a fan of the new 1533 HST, I was about to sign on the dotted line for one until I found a used cabbed 05 4320 which I love.
It's smooth driving and I was really impressed with how smooth the FEL was. For my needs turbo 48hp is more than plenty, half throttle for most of my tasks with FEL. Mine is a 3 range HST, shifting into the diff ranges can be a bit of a bear but mostly I'm in mid range.
I really like the separate forward and reverse peddles, I wouldn't prefer a heel toe, I could get used to one but wasn't a fan of the ones I looked at. Mine is 4wd and even know my tractor weighs in at around 5200lbs, 4wd is needed often, I'm running unloaded R4 industrial tires (stock titans).
I looked at the E series 3038 JD and wasn't really a fan, it could lift more and was heavier than the L4060 I looked at but I liked the Kubota better, I liked the Mahindra most of all.
Yes the L non grand has 3 range HST, the E series has a 2 range. The Mahindra had a 3 series HST and could lift 500lbs more on the FEL.
I wouldn't say my tractor is too big, I would say it's perfect for what I need it for, that's moving round bales with FEL and clearing snow with a rear blade, both jobs it exceeds at.
One very important bit of info I got off here, on a grade with a heavy load on the FEL pop the tractor in 4WD, if the rear gets light or comes off the ground and your in 2WD you no longer have breaks, a bit of info I didn't have to learn the hard way thankfully.
TANK MANIFOLD (A55745)
Utility Cart (A59228)
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
Landoll Lowboy Trailer (A56438)
Landoll Lowboy...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
2020 HINO 268 26FT NON CDL BOX TRUCK (A59575)
2020 HINO 268 26FT...
