Deciding to get another grey.
   / Deciding to get another grey. #1
Yandaddy1110
Elk River, mn
Yanmar YM1110D, John Deere 955
I have started a home-based business which involves unloading pallets of merchandise off a semi-trailer truck. No loading dock obviously. Been renting the neighbors skid steer for the task,unfortunatly leaves ruts and tears up the drive and the lawn to the pole shed where I store the mechandise. My question, what size tractor could handle 700lbs palleted loads with a 3ph safely. BTW I have a yanmar 1110d and am very familiar with grey market kubotas,isekis hinomotos ect. just not the 20 + hp types.
   / Deciding to get another grey. #2
Hmmm?
No loading dock...
Pallets on the 3 ph....
Experience with tractors less than 20 hp....
Using skid steer now.....
I cannot piece this one together. What am I missing?
   / Deciding to get another grey. #3
I would use anything less than a 30hp 4x4 w/FEL.
Then, affix pallet forks to the front of the bucket.
What you might also need is an attachment on the rear 3pt for balance.
That's a bunch of weight out front for any compact tractor.
Sorry, I should have mentioned the fact that I would convert a single stage forklift mast that I have to 3PH and use that off the back of the tractor. Mast weighs maybe 300lbs and has a lift cap. of 1000lbs. Another factor is 2wd should be OK for this type of use, and also, I have a loader sitting out back that someday I would install.
Hmmm?
No loading dock...
The skid steer works, its rented from neighbor. Problem is this is semi-rural residential, I want to keep this businesss low impact with the neighbors, the smaller the tractor the better as far as that is concerned. So far semi comes every- other month, so a Bobcat is kinda overkill, plus I would like to have my own machine here when needed and not rely on someone elses machine to be available.
   / Deciding to get another grey. #6
If I misread or misunderstood, please clarify...you are not going to unload a semi from ground level with forks on the rear of one of these tractors. Front forks on something 25HP and 2500# or more, perhaps, bu the 3ph won't lift high enough. It will carry your pallets, but not unload a truck.
   / Deciding to get another grey. #7
Why not get an old US gas farm tractor? Any of the ones which have a standard 3ph will handle the load with ease. Inexpensive, known reliable, stable with a load, good parts, and the gassers start easy in cold weather. Much as I like compacts, this sounds like an application for a good old haying tractor. Your money will buy a nicer machine, too. Put balloon tires - or truck tires - on it for a nicer ride.
rScotty
Yes I am thinking of unloading the semi from the ground using a 3PH forklift mast, single stage which I already have,and should lift 6' high.The mast plus the pallet would weigh aprox. 1000lbs. I have considered a loader with forks, but that is really not ness. with a 3PH forklift mast.
rScotty
I did once consider an old gasser, yes it would work. I would like to remain in the grey compact world though, I dont want old farm machinery in a residential area.
   / Deciding to get another grey. #10
Morris,
I think you are looking at this the wrong way. Re-consider bucket forks.
Add on bucket forks are a great attachment. They are simple to put on, allow you to look forward to drive your load around and there is no design work or hydraulics to figure out.
I use mine all the time for moving just about everything. With my New Holland TC29DA I can carry about 800 lbs max. A bigger tractor would do much more.
   / Deciding to get another grey. #11
Are you moving shipments of drugs or something? Residential . . . shipments every other month . . . no loading docks . . . low profile. . .
Fishy. . . very fishy.
   / Deciding to get another grey. #12
At one time I would have thought that was an unusual viewpoint. But that's because I've never lived in town. From talking to friends where I work sometimes there are even lots of places that have regulations against farm machinery being out where it can be seen. Other places seem to consider things like a an old Farmal or JD or hay rake to be yard art or sculpture....a sort of "Americana", and scatter a few pieces around the yard.
I've got a buddy who lives in town in a neighborhood with a "block committee" who decides what is acceptable and what isn't. The upshot is that he isn't even allowed to park his pickup on the street. That would bother me but doesn't bother him. So that's OK.
rScotty
   / Deciding to get another grey. #13
he could be selling trinkets on ebay, none of my business. but i also vote for the pallet forks on a frontend loader. they can also reach in a little
   / Deciding to get another grey. #14
With any compact grey other than one of those monster yanmar ym7000 or something i dont think a little compact iseki mitsu yanny or himoto will hold your 300lb fork mast on the 3pt and then hole another 700-1000 lbs off the back 6 feet in the air and be stable or safe. It will wat to tip backward once the load is on it before you can lower it wich will be very unsafe. to give you an example. my yanmar ym2000 is 24 engine hp. I have ~80lbs front weight and with my boom pole on the back i can pick up my buddies 4 foot tiller to put it in the back of my truck. I estimate the tiller to be between 300-400lbs. While i feel very safe and stable i keep it low so if it swings or i start to tip back i can let it to the ground. The only time it is waist high is to put it into the truck bed. Im actually off the tractor controlling 3pt hitch and rolling the rear tire, this turns my tractor into a cherry picker or like an engine lift. Anyway this realitively light load even though its 4 feet off the back still really lightens the front of my tractor where i can almost pick the front off the ground that much weight has shifted from the lift. This is on a 1800lb tractor. My point is even if i was a like a ym 2500, close to 30 hp engine (next bigger sixe frame tractor)i think you would still be veryunsafe lifting 1000lbs up 6 feet in the air off of a semi.
I too would get an old jd from the 60's or an old ford. there heavy as h3)) even though there not much hp they can pull a house and lift it too. LOW profile is not a SEMI pulling up to your house every other month or so. And sounds like you have a shed/barn already, park it inside or behind it or build a leanto off the side to park it under. If you dont want your cool old historic tractor to be seen by you to good for you neighbors (i have some) put tin side on that lean to, it will darken it inthere where its hard to see in, or put doors on it to make a tractor garage, or put sides on it and face the opening to the back away from the road. I try and keep my tractor hidden form the road myself as they are very easy to steal and between 4wheelers and CUTs a very hot item among the tweekers.
   / Deciding to get another grey. #15
How do you find grey market tractors and how much do you save? They sound like you have to whisper a code word to someone who takes you to the basement of a warehouse where under a cover in the back their is a 'Bota staight off an unmarked container.
   / Deciding to get another grey. #16
Any of the sales ads or craigs list is full of "greys" you just have to know what your looking for. All yanmars of a certain # u know are grey, all Iseki are greys some himotos, all Mitsubisis are greys, and some of the Kuboboos that have been here a while are possible greys all though i dont know much about the kubo market.
   / Deciding to get another grey. #17
There is a guy in Minneapolis ( Bernstenengle Eq.) could be spelled wrong but I bought my 1st tractor from him and he sells a good product. You have to be carefull of some Greys because they are poorly refurbished and painted to look like new. Anyway I bought a 30hp Iseki and have loved every minute of using it. Very durable with tons of special options. I am now ready for a larger tractor and am unsure where to sell the Iseki other than e-bay or craigslist. Maybe both. Anyway there are some very good tractors coming out of Japan.
   / Deciding to get another grey. #18
Problem with those Iseki or sharabus (i know not japanees) or Mitsubishis, is lack of replacement parts, say axle seals or gears or spindles or other things. Of couse yoiu can prolly get easy common things like injectors bearings and starters and alts and things.
   / Deciding to get another grey. #19
Yeah, I read where guys are looking for odds and ends parts for the Jap Greys. The guys in the Iseki forum seem to get taken care of but I have no idea where they source their parts. I have been lucky to not need any. My particular Iseki is almost a direct cross to a Massey 1240 so manuals and parts are out there at the Massey dealers. Some have no direct cross..Lucky for me I guess....
2018 NEW HOLLAND C232 SKID STEER (A60429)
2018 NEW HOLLAND...
2004 JOHN DEERE 160C LC EXCAVATOR (A59823)
2004 JOHN DEERE...
2018 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2018 MQ POWER...
2007 Ford E350 (A55973)
2007 Ford E350...
iDrive TDS-2010H...
2023 VOLVO ECR25 ELECTRIC EXCAVATOR (A60429)
2023 VOLVO ECR25...
