Decided on 2305 Instead of X748
   / Decided on 2305 Instead of X748
JDFANATIC...as i understand, the mulch kit consists of baffles to keep the clippings confined for more cuts by the blades. It costs $146. So since my lawn gets cut between every 2 - 4 weeks depending on my work, should I mulch or stick with Gator blades? How are Gator blades different from standard blades? Also, is the mulch kit easy to uninstall/install and does it have special blades as well. I want to avoid a big mess in the yard. I don't have Kentucky type thick lush grass...it's a collection of different types of grass and varies in density and thickness according to ground moisture in different areas. Thanks for any more advice.
   / Decided on 2305 Instead of X748 #22
Engine66,
Check out this post (I think #22 are some pics I took): http://www.mytractorforum.com/showthread.php?t=41787&page=2
The mulch kit does take special blades that aren't compatible with the std. Deere blades or the Gators. I'm thinking that just a set of Gator Magnum (I just discussed the new Gator Predator blades with my dealer and he suggested I stick with the Magnums) would be a good place to start. From my experience they work great. I only picked up the mulch kit to see how it worked and was thinking they may have an advantage for leaves with the closed chute area.
   / Decided on 2305 Instead of X748 #23
Reference the JD 2305!!!!!
Does anyone see any solid reason why the Powerflo turbine will not work with the MC-519 cart.
Does anyone know what the cost would be without the bagger assembly?
Is there any compatibility problem with the Powerflo turbine and the GATOR
blades.
   / Decided on 2305 Instead of X748 #24
I have a MC-519 that I had a 3-pt hitch assembly built for - I use it on my JD2305 with a 62C deck and a JD PowerFlo kit. Works just fine.
Can't comment on the cost or the gator blades - bought mine used from a JD dealer and with the bagger assembly. Don't use gator blades as of now.
Scott
   / Decided on 2305 Instead of X748 #25
assuming they are similar, I have a mulch kit for a 42C mower. It goes on with one cap screw and wing nut. Takes about 5 minutes or less. You need to make sure you have mulch blades on though. The standard blades and mulch blades are not the same length.
   / Decided on 2305 Instead of X748 #26
Scott,
Could you please post a closeup picture of your modified hitch assembly for the JD 2305 and MC-519 cart. I have the cart on hand now. Also did you buy the POWERFLO KIT separately or with the bagger? My cart came with a POWERFLO KIT for the x425. I don't think that is the same as the one you have. Do you have a part number for the POWERFLO KIT that fits on the 62C
i did not get a manual on the POWERFLO KIT.
   / Decided on 2305 Instead of X748 #27
Powerflo prices, and numbers are on the Deere site under build your 2305. Hope this helps.
   / Decided on 2305 Instead of X748 #28
Scott,
I'll do a write-up with photos this Spring when I'm switching out my snowblower for the MMM and bagger. It's all tucked away right now and not easy to get at until I do the "big switch".
Scott
Seppi Mini BMS 85 Mulcher excavator attachment (A51039)
Seppi Mini BMS 85...
2016 Ford F-150 Ext. Cab Pickup Truck (A50323)
2016 Ford F-150...
2023 BANDIT SG-75 STUMP GRINDER (A51242)
2023 BANDIT SG-75...
2011 FREIGHTLINER CASCADIA (A50854)
2011 FREIGHTLINER...
2015 VANTAGE TRAILER CRUDE TRAILER (A50854)
2015 VANTAGE...
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
