Decent older commercial grade mower recommendations
   / Decent older commercial grade mower recommendations #1
Mikefromcny
Upstate NY
White 2-65, Kubota B9200
Hi all, looking for a mower to replace her box store zero turn that's been anything but reliable.
Budget is around $3500. Could possibly do a little more. I've owned Lazer z's and thought they were a good mower.
I currently own a Kubota f2560. 2 seasons on it. It's been great. I'll let her use this while I run my 5' finish mower on the back of my Kubota tractor.
She'd like a zero turn, but would take a good out front mower.
Here's my understanding..
Exmark, Scag, Kubota - good mowers.
Toro groundsmaster..parts availability? Reliable?
Jacobsen turfcat - owned by Textron, expensive parts, and older ones are getting long in the tooth.
John Deere f series - old, parts availability?
She mows 2.5-3 acres once twice a week.
Diesel would be nice for longevity, and fuel consumption.
Not really looking for anything new but an older commercial grade mower.
I'm a diesel tech so not worried about repairs, just want something I dont have to work on every week.
Thoughts?
   / Decent older commercial grade mower recommendations #2
Charge up that flux capacitor and aim for 1990.
Personally Id consider moving if I had to mow 3 acres every week on a tight budget. Sell now while the property values are up and rent a small place instead.
   / Decent older commercial grade mower recommendations #3
I use a JD F-935: diesel, 2 tanks, aux hydraulic, cab available, blades are cheap even from my dealer, car battery.
All I've ever put in it is a battery, tire tubes, ignition switch and glow plugs. I pull a Woods leaf vac behind it without any strain. I also can hook up my PTO farm generator to the deck prop shaft and run the house off of it.
Parts manual on-line free. Lots of new and used parts for them on ebay. I often cut 10+ acres with it. Originally used to cut the fairways at a local golf course. They are all over the place here for under $3000.
PALLET OF SCAFFOLDING (APPROX. 18 PC) (A52706)
PALLET OF...
2013 Crane Carrier Co. Low Entry Loadmaster Excel-S 25 Yard Rear Loader Garbage Truck (A51692)
2013 Crane Carrier...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A53473)
2012 JOHN DEERE...
2022 Toro Workman 07921 Electric Utility Cart (A51694)
2022 Toro Workman...
2015 Ford F-450 Knapheide Service Truck (A51692)
2015 Ford F-450...
2023 Ford Explorer AWD SUV (A51694)
2023 Ford Explorer...
