Dearborn Chisel Plow/ Field Cultivator Sweeps
   / Dearborn Chisel Plow/ Field Cultivator Sweeps #1
Travis_R
Livingston Parish, LA
Yanmar YM2500
I am fixing to order some sweeps for my chisel plow. I use it for cultivating the rows in my garden. There are are a total of 6 tines, (3 per side).
I was told it is a Dearborn model 13-2. My question is how do i know what size and demensions of sweeps to order?
The "tine" measures 1 3/4" outside to outside. 2 sweeps that are currently on there now are 8" sweeps.
I think i am needing (2) 10" sweeps to do what i'm wanting to do. I just don't know the correct ones to order.
Any help is appreciated.
Thanks
   / Dearborn Chisel Plow/ Field Cultivator Sweeps #2
Travis, are you wanting to make beds for planting or just use the sweeps in between the rows to kill weeds and vegetation?
If the latter, how wide are your rows from the center of one bed to the center of the next one? For that use, I would choose a sweep that was wide enough to kill as much vegetation as possible without cutting the roots of your garden plants.
What you are referring to as "tines" are typically called "shanks". Take one of your existing sweeps to your local dealer so you can be sure to buy the right size sweeps that will match the width and bolt pattern of your shanks. I'm not positive, but I think the bolt patterns on most shanks are pretty standard.
2005 Ford F-550 Bucket Truck, VIN # 1FDAF56P45EB88239 (A48836)
2005 Ford F-550...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
New/Unused 20ft Farm Metal Driveway Gate (A48837)
New/Unused 20ft...
UNUSED CFG Industrial QK16R Mini Excavator (A47384)
UNUSED CFG...
International 806 2wd Tractor (A52128)
International 806...
1999 CATERPILLAR TH82 TELESCOPIC FORKLIFT (A51242)
1999 CATERPILLAR...
