Dealers Ignoring Spark Plug change intervals?
   / Dealers Ignoring Spark Plug change intervals? #1
ultrarunner
Epic Contributor
SF Bay Area-Ca Olympia WA Salzburg Austria
Cat D3, Deere 110 TLB, Kubota BX23 and L3800 and RTV900 with restored 1948 Deere M, 1949 Farmall Cub, 1953 Ford Jubliee and 1957 Ford 740 Row Crop, Craftsman Mower, Deere 350C Dozer 50 assorted vehicles from 1905 to 2006
Back in the day it was common to change out plugs and points at 10k miles.
Cars have not had points since the 70's and spark plugs last a long time.
Recently I have been hearing dealers dissuading owners from changing plugs.
One of my friends took in his bought new and only dealer serviced 525i that is 15 years old and just hit 100k.... the dealer did not change out the plugs even though the service manual called for it.
My brother took in his Chrysler 300 which hit 60k miles and also calls for a plug replacement and the Dealer said they don't do that.
Sounds strange in this day when service writers are always trying to pad work orders...
Have heard of expensive head repairs when plugs were taken out hot or never taken out.
Any thoughts?
   / Dealers Ignoring Spark Plug change intervals? #2
That's stupid, when I was a dealer tech I sold everything I could including windsheild wipers. Hemis have a short tune up interval b/c copper plugs.
Seems odd to me...
The 300 had the V6 and was bought 6 years old with 5200 miles... my friend bought it new and then health issues prevented him from driving... so it basically sat for 5 years until he passed and his kids sold it.
   / Dealers Ignoring Spark Plug change intervals? #4
Yeah we just bought a 2006 jeep wrangler with the I6. I knew that it had copper plugs so I went to my favorite parts house (proffesional type sells ac delco motocraft and mopar) to get plugs. The counter guy was shocked when all he could get was copper plugs. I said yeah that's why dodges are cheap, they use cheap parts.
   / Dealers Ignoring Spark Plug change intervals? #5
I change the plugs on my diesel regularly- even though the dealer says I don't need to!!
The material used to make the plugs allows for a longer interval between changes.
   / Dealers Ignoring Spark Plug change intervals? #6
When I worked at Ford they saved on explorers by only platinum plating the center electrode on one set of cylinders and the ground electrode on others. The way those ignitions worked, 2 cylinders fired at the same time and were in the same circuit. So the spark jumped from the ground electrode to the center in one cylinder through the wire and coil from the center electrode to the ground on the companion. You only needed precious metal on the electrode that the spark jumps off of, to keep it from eroding.
   / Dealers Ignoring Spark Plug change intervals? #7
I hear you there Mate! :thumbsup: And none of those generic brand plugs either; it's too important not to go with genuine OEM!!!
   / Dealers Ignoring Spark Plug change intervals? #8
I do not change spark plugs on modern vehicles. What's the point?
I also do not ever buy 'fancy' performance enhancing plugs. I did when I was younger and stupider.
It can also be a HUGE undertaking to change plugs on a modern vehicle. The rear cylinders on rear wheel drive vehicles can be practically under the dashboard.
I tend to keep vehicles forever.... 45 years ownership is the longest and my new cars are circa 2002
Have not changed a lot of plugs but my 1985 Chevrolet has benefited from plug replacement.
One of my mechanic friends said plugs are often left in until there is a problem as in drive-ability or failing State emission testing... a plug which would otherwise be simple to change can be problematic.
On the Chrysler 300 the owners manual calls for 60k change intervals... dealer said NO...
   / Dealers Ignoring Spark Plug change intervals? #10
Any turbo or supercharged gas motors will be hard on spark plugs. It's always been that way and always will be, just how it is. My ecoboost destroys plugs in about 25k, even with an OEM Platinum plug. They're easy to change though.
Now I see why some oem's use a long lasting plug, my wife's Mercedes called for 6 hours shop time just to change the plugs. The entire intake has to be removed to replace, crazy. Never will own a Mercedes again, it seemed like it was made to last 10 years and then throw away.
With modern ignition systems however, plugs can last a long time. So I don't think there is a blanket rule that applies anymore. It all depends on what you drive.
UNUSED FUTURE 32"...
2018 Chevrolet Impala Premier Sedan (A55853)
2018 Chevrolet...
2007 Chevrolet Impala Sedan (A55853)
2007 Chevrolet...
2014 Ford F-150 Pickup Truck (A56858)
2014 Ford F-150...
2018 PETERBILT 579 DAY CAB (A57880)
2018 PETERBILT 579...
2012 BMW 328i Sedan (A55758)
2012 BMW 328i...
