Dealer Overfilled Transmission Case and Engine CC
   / Dealer Overfilled Transmission Case and Engine CC #1
Stuckin67
I recently purchased a lightly used B7510DT that had just had the 50 hr service performed at the dealer's . They overfilled both the transmission and the crankcase. The transmission fluid registers a full inch above the top mark on the dipstick.
The gear drive model takes 1/2 gallon less than the HST and I think they failed to take that into account. What is the best way for me to drain off the excess UDT fluid? How about the excess engine oil?
   / Dealer Overfilled Transmission Case and Engine CC #2
Its probably fine, its okay to overfill those by a small margin. If its too much fluid for the trans it will just blow it out the breather, nothing to worry about.
Thank you for the reply. I put the loader to moderate use for 1.5 hours on a pile of dirt and found it to jerk quite a bit. Don't know if the excess fluid can affect performance before being blown out the breather or not, but I thought it might be worth the effort to take some out.
   / Dealer Overfilled Transmission Case and Engine CC #4
doubtful, its probably the viscosity your noticing. Its normal for things to feel different after an oil change.
   / Dealer Overfilled Transmission Case and Engine CC #5
Consider yourself lucky you got some bonus oil!! I little extra won't hurt. I'd leave it.
Rob
2012 Caterpillar AT1055E Track Asphalt Paver (A51691)
2012 Caterpillar...
2023 G Bar K Goose Neck Flat Bed (A53472)
2023 G Bar K Goose...
Bobcat 14" Hydraulic Asphalt Plainer (A52384)
Bobcat 14"...
UNUSED RAYTREE RMBD50-50" DRUM MULCHER (A51248)
UNUSED RAYTREE...
UNUSED TOPCAT SSSCR72-72" HYD SOIL CONDITIONER (A51248)
UNUSED TOPCAT...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
