Dealer/Deere Replacing My 72D ?
   / Dealer/Deere Replacing My 72D ? #1
mcgill72143
Arkansas
2013 John Deere 3320 Cab
The dealer called me just before delivery and said there was a problem with my deck. They contacted Deere and they're replacing my 72D because of a cracked weld on the small plate the tire rides off of......It happened when the service guy drove over it to connect it. The dealer let me use the deck till the new one comes in. I cant believe Deere is replacing the whole deck over this weld but I guess if one weld was bad then there's no telling what others were bad too. Here's a pic of the left side. The right one is also showing signs of cracking paint on the weld.
   / Dealer/Deere Replacing My 72D ? #2
That's weird. My deck is a year older than yours and I don't have that plate. The 2 pulley guards Are steel on mine and they overhang a little for traction while driving over. weld broke because it looks to be something of fragile design. Ill go out and take a picture of mine after coffee
   / Dealer/Deere Replacing My 72D ? #3
here is my deck. both sides are the same and you can see the steel guards overhang from and back with no welds
   / Dealer/Deere Replacing My 72D ? #4
Must be something that just got added. Here's a photo of mine. Only 2 weeks old. Must be Deere thought it would help soften climbing up and back down...
   / Dealer/Deere Replacing My 72D ? #5
You know Mike, It looks like Deere did a complete redesign of the gauge wheel mounts. While yours are straight on the deck, the new mounts appear to be angled out. Wonder if has something to do with allowing wider wheels/tires from now on? :confused3:
   / Dealer/Deere Replacing My 72D ? #6
Hmmm, I have to keep an eye on mine. Thanks for posting!
   / Dealer/Deere Replacing My 72D ? #7
That's a good point. When I get my machine back this week. Ill have to take some measurements from the wheels
   / Dealer/Deere Replacing My 72D ? #8
They put a new gearbox on mine before delivery. They said it was a little too noisy. I was surprised they just didn't leave it alone and hope it out lasted warranty.
   / Dealer/Deere Replacing My 72D ? #9
For what you paid for it they darn well should replace it.
TEST YOUR BID BUTTON! (A52706)
TEST YOUR BID...
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
2013John Deere 244J (A47477)
2013John Deere...
2019 MACK P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK P164T...
Pull-Behind 66in Smooth Drum Ballast Roller (A51691)
Pull-Behind 66in...
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
