Deal on a JD110??
   / Deal on a JD110?? #3
Could be. It's at a dealer in N.Wilkesboro. Apparently a 10 yr. old machine, but in the photos it looks to be pretty clean. 110's were good machines.
   / Deal on a JD110?? #4
I just bought a 110. I did check this one out (it's on rock and dirt as well) and it doesn't have a BH. Don't understand why you buy a TLB w/o the BH, but is a very nicely equipped tractor if your looking for a tractor that size and don't need a BH:thumbsup:
   / Deal on a JD110?? #5
Lots of uses for a tractor loader with topntilt hitch, remember that the fel is heavy duty and the front axle is heavier built than the 4x20 series too. So combined with a good boxblade it makes a good compact sized landscape loader. You can always add a hoe to it if desired. I have a friend who has four 110s' all with boxblades and two hoes in his yard that the crews can grab when needed.
   / Deal on a JD110?? #6
Here's a brand new, never used 110 backhoe with thumb (no tractor). Also has what appears to be a rear window and frame!! Very similar to a Laurin cab.
Unfortunately, it's in Canada! (Not too bad a trip for me, though... :laughing:) Oh yeah... the link - http://www.machinefinder.com/ww/en-US/machine/1500436
AKfish
2012 Ford F-250 Ext. Cab Service Truck (A50323)
2012 Ford F-250...
2803 (A50460)
2803 (A50460)
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
2015 MACK GU713 DAYCAB (A50854)
2015 MACK GU713...
3 pt Aer-Way (A50514)
JOHN DEERE 975 3 BOTTOM SWITCH PLOW (A51243)
JOHN DEERE 975 3...
