dead? tractor
/ dead? tractor #11
Trace wires from pedal switch back to the interlock switches for PTO and range if they are used, sounds like a wire is cut and grounded in the circuit someplace.
David
/ dead? tractor #12
I may have lost part of this story but I disagree with David and others. I doubt it has anything to do with the interlock switch or wiring. Typically that wire satisfies the start system only by completing a path to ground. There is no hot wire to an interlock switch. All that interlock stuff might do it is allow you to start while in some forward or reverse setting and hurt somebody, not blow fuses. I don't think that is involved. You have not said what the fuse protects that keeps blowing (and it probably does not matter.) You must have a bare hot wire being contacted by the hydrostatic fore/aft pedal or the linkage and mechanical parts connected to the pedal. The fix is to find that wire and wrap it as well as get it out of the way of moving metal. Now, I'm going to stick my nose in your business enough to say -- you need to be adept if not truly comfortable taking that deck on and off. I enjoyed that "get down and can't get back up" stuff you guys described so well ! I am 73 myself and isn't that a **** of a thing we all have ? Don't be bashful -- you've got a grandson, neighbor, some dude you helped 8 or 10 times -- that can help you pull the deck and get it back on. You really gotta get down under there where you can see all the crooks and crannys and find that wire. That or be willing to pay the dealer to find it.
/ dead? tractor #13
When the pedal is pressed does the engine shut off quickly or does it lug down and die?
Seems there are some redundancies here!
There are times a nice bright light and a mirror let you see into them hard places.
Also look at the fuse and relay boxes and pull/ clean/replace them all. Pull the fuse that's blowing with the tractor running. Any and all wires that can be reached could be handled when the engine is running. Might find the one causing problems.
/ dead? tractor #14
" Unfortunately, while I used to do all the crawling around on the barn floor, I'm 74 now and not so inclined any more"... Trade it in on a new one with the drive over deck while the dealer has it...lol :laughing: You can always ask the wife for forgiveness afterwards. :D
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
2017 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A60352)
2017 Peterbilt 567...
2012 Kenworth T800 T/A Sleeper Cab Truck Tractor (A60352)
2012 Kenworth T800...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
KJ K1912 20'x12' Shed (A60463)
KJ K1912 20'x12'...
Iranch IRET13 (A60463)
