Dead Small Equipment
   / Dead Small Equipment #11
I really appreciate small engine makers who put a DRAIN SCREW in the bottom of carb bowls. It's the ONLY way to really get them totally empty. I too have had just that few drops left in the bottom by running the engine dry cause gum/varnish/hard starting.
   / Dead Small Equipment #12
Pull the plug and inspect.
Leave it out.
Fill the fuel tank completely.
Pump the primer bulb if equipped.
Pull the starter and see if fuel/air comes out the plug hole.
If no, drain fuel tank and inspect fuel line and filter.
If yes, reinstall plug, shoot a short burp of starting fluid into the carb and see if it fires on that.
If yes, probably a fuel system problem... carb, fuel line, filter
If no, probably a spark issue.
   / Dead Small Equipment #13
They say the measure of a man is how many small engines he can keep running. I always run mine with the non ethanol fuel and run them dry. I would also find a good small engine mechanic. Sometimes these big box engines aren't the best quality. I had a Husqvarna chainsaw that I always had trouble starting. Took it to the mechanic and he had it for a few weeks and now the thing runs awesome and starts on first or second pull. I also agree with the other comment about running them frequently. The more I use mine the easier they seem to start and the better they run.
2018 PJ TRAILER 32FT GOOSENECK TRAILER (A58214)
2018 PJ TRAILER...
2007 Kenworth T800 Tri Axle Day Cab Truck Tractor (A56858)
2007 Kenworth T800...
2016 Husqvarna YTA18542 42in Riding Mower (A56859)
2016 Husqvarna...
2023 Kubota M4-061 Deluxe MFWD Utility Tractor with LA1154 Front Loader (A55315)
2023 Kubota M4-061...
Case Skid Steer Backhoe Attachment, S/N 391998, 20" General Purpose Bucket, Asset# 71 (A59076)
Case Skid Steer...
2020 INTERNATIONAL MV607 REEFER BOX TRUCK (A55745)
2020 INTERNATIONAL...
