Dead perkins....(ie, help...)
   / Dead perkins....(ie, help...) #1
Richard
Super Member
Knoxville, TN
International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
I am lost and hope some diesel experts might have some ideas.
Setup: Working Brutus all day, dragging sections of fallen oak tree back to field near house. (point being, started fine, ran fine, plenty of fuel)
Was dragging large branch, slipped into neutral, started to ease backward some, so I clicked back into forward... (engine speed was at idle), as the reverse to forward load hit with essentially no rpms, engine died. (kind of analogous to killing engine when learning how to use clutch)
Not a problem...I've managed to do this a handful of times in 2 years of ownership.
Turn key, and engine turns over, but will NOT start. No sputtering, no smoke, no passing go, no $200.00.
Outside temperature is probably near 50 degrees, so nothing frozen up in fuel line. New fuel filter this past summer. Loosened one of the lines to injectors while someone else turned key, fuel "seeped" (as opposed to spurted) out. While turning over, looked at rain flapper... it was bopping up and down (was thinking if timing chain broke, no "timed" exhaust).
Thankfully, Brutus died in field across from house... the big oak tree that fell was out on the public road and that is where I had been working...had it died out THERE... no one could have easily gotten by /w3tcompact/icons/blush.gif.
Ohh.. to clarify, if I remember correctly, the fuel injectors (is it even POSSIBLE for them to lose their prime with a stall like that??) anyway, the injectors are let's say, 1 1/4 inch diamater wrench, on TOP of them with a 1/4 inch bolt, is the fuel supply line. It is the supply line and not the actual injector I loosened (presuming my differentation is correct) My handy wrench at the scene was not large enough for the injectors per se.
I'm now looking for ideas of what to look at.
Though I don't see how it would matter in literal sense, don't forget Brutus is industrial JCB & not a tractor (please don't banish me from here...I WANTED a tractor... mean wifey forced me to get this instead /w3tcompact/icons/cool.gif )
Richard
   / Dead perkins....(ie, help...) #2
Well it's not a perkins but on my Cat E110B excavator I was operating it and started wiggling or actually throwing the girl all over crawling over rough area and digging blah,blah and the motor actually just started sputtering like crazy and went dead. Well after thinking about it racking my brain someone lead me in the direction of fuel......my suction strainer inline of the fuel filter before the primer was completly clogged with smudge or ???? The unit would turn over all day just fine but nothing .....sputter or smoke....When I went and primed the pump for fuel it ran but would die in the matter of seconds until I cleaned that strainer. LONG STORY SHORT ----check your strainer if you have one.
Darin
   / Dead perkins....(ie, help...) #3
Kinda sounds like a safety switch close,or a loosen maybe broken wire.
If it was I start tracing the wires,also check the fuel filter to see if the fuel flowing...might be worth checking all the fuses..look for the little things first before tearing into the big stuff...my motto. /w3tcompact/icons/hmm.gif
ok.. was your strainer in your tank or near filter?
I have a sneaky feeling that had I not stalled it, it would have kept running until I stopped it "normally" (and then maybe not have restarted). It was running smooth and not hiccupping at all. The timing of the stall, with the lurch of the transmission would be tooo ironic for it to have run out of fuel in my mind (though that IS the kind of luck I have /w3tcompact/icons/laugh.gif)
I'll call dealer tomorrow & ask (if and where strainer might be)...fortunately, they are very helpful with me... patient is probably is a better word though...
   / Dead perkins....(ie, help...) #5
Richard,
Actually the strainer was just a real fine mesh that was inline of the fuel injectors...It's in the same line that feed the injector pump (suction). But like you mentioned the timing of the stall probably isn't the fuel strainer but maybe some other safety switch like Bird mentioned. The only problem with the safety switch is that the motor turns over just like it should unless there is a blower (air)switch or fuel shut off switch. Are all your idiot lights coming on when you turn the key? I'm really not sure but am sure that someone here will help you more.
Darin
   / Dead perkins....(ie, help...) #6
I'm no expert by any means but I'd check compression and then fuel pressure at injectors should tell you which way to go
   / Dead perkins....(ie, help...) #7
You should have a fuel cutoff solenoid on the injection pump. Use a 12v test light to see if you're getting power to the solenoid when the key is on. Maybe the wire fell off. :)
   / Dead perkins....(ie, help...) #8
My truck has the fuel solenoid shutoff. When it failed the engine would not shut off. Had to stall it. When I found where it was The lever to the valve could be manipulated by hand.
The replacement cost was a mere $600 Canadian. I was tempeted to install a cable to the valve and operate it manually.
Egon
   / Dead perkins....(ie, help...) #9
If all else fails, check the injector pump. If it has to be rebuilt or replaced make sure you are sitting down. bcs
   / Dead perkins....(ie, help...) #10
Along with all of the other things, remember to check for air in the system. Any significant air can cause the fuel system to stop working... It can come from a slight crack in any fuel line that is under suction (before the fuel pump). It can also be trapped in the system by a problem with the fuel return line. A quick (and cheap) way to check for air is to install a clear insert between the fuel transfer pump and injection pump, and turn the engine over...
2018 CHEVROLET SILVERADO 2500HD (A53843)
2018 CHEVROLET...
2004 Wabash National 28ft Dry Van Trailer (A51692)
2004 Wabash...
2017 Chevrolet Silverado Schwarze SuperVac Updraft Sweeper Truck (A51692)
2017 Chevrolet...
2013 Nissan Juke SUV (A51694)
2013 Nissan Juke...
2019 Ford Econoline Ambulance (A51692)
2019 Ford...
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
