Dead Oats covering fall Alfalfa. Can I burn it?
   / Dead Oats covering fall Alfalfa. Can I burn it? #1
svenlylethor
UT
JD 5420, 6430, & 6125R
I seeded fall Alfalfa directly on a field where I harvested Oats. I irrigated the field and some of the Oats grew with it. Some of the Oats grew a good 10 inches and died from winter so now. Now I've got a few places where it's caked on my field and it's preventing the Alfalfa from growing.
I was thinking about running a harrow over it on a low setting to break it up but now that it's burning season, do you think it would kill the Alfalfa if I just torched the bad spots?
   / Dead Oats covering fall Alfalfa. Can I burn it? #3
Yep I'd harrow it too
If it's real heavy, you could maybe rake it to the corners and burn/ take away for compost. Fire will just scorch the seedlings.
At least oat straw doesn't become too acidic as it decomposes, like other cereals. Wheat and barley straws hurt seedlings if left too heavy and then rain/irrigation follows.
   / Dead Oats covering fall Alfalfa. Can I burn it? #4
They would burn it off around here. Should not hurt the Alfalfa. Check with you local agg office too
2019 Freightliner Sprinter 1500 Van (A50323)
2019 Freightliner...
1999 Case International MX200 Tractor (RIDE AND DRIVE) (A50774)
1999 Case...
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
2004 Toro Turf Sweeper 4800 (A50322)
2004 Toro Turf...
2018 John Deere HPX815E 4x4 Gator (A50121)
2018 John Deere...
40' High Cube Container (A50121)
40' High Cube...
