Dead CK30 tachometer
/ Dead CK30 tachometer #11
I have done on vehicles exactly what you said about using the silicone tune up paste to lube keys, dipping it in, operating ign/or lock several times and wiping any excess off key.
Dry graphite in moderation shouldnt be a problem, it doesn't wet leach into contacts so my non scientific survey says its ok.
So far all is well after the eparts cleaner. I spent a half day running it on Friday and the tach worked great. The throttle, however, had frozen up and needed additional wd-40 to break it loose. I'll try chain lube from the motorcyle section next time.
/ Dead CK30 tachometer #13
I see the growing list of Highbeams spare parts:
corner light, ignition switch, tie rod bar, loader frame, throttle linkage- and of course the usual list of filters and oils... lol
/forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Think I've got everything handled though except for that loader frame. That's a biggy. They don't make you keep the old one do they?
Then there's that silly dash with the clear plastic cover. I have gotten a good bit of dust behind the cover in a couple of hot spots. No water yet though.
Need a brush guard. I tried making one but can't find the time. Would rather be in the seat.
The real question is how many times do I break the same thing twice. I tend to learn my lessons about the equipment's limitations and not exceed them again, maybe I can pass a few of the particularly painful lessons to the TBN folks.
/ Dead CK30 tachometer #15
</font><font color="blue" class="small">( I'll try chain lube from the motorcyle section next time. )</font>
Get you some of the white litium delayed viscosity spray lube. It works great, and lasts a long time.
John
MMS 750 Remote Control Lawn Mower (A60463)
MMS 750 Remote...
John Deere 5055E (A53317)
John Deere 5055E...
607 HD PRO CHALLENGER VACUUM PUMP (A60736)
607 HD PRO...
INTERNATIONAL EAGLE ROAD TRACTOR (A52707)
INTERNATIONAL...
Bush Hog RDTH84 (A60462)
Bush Hog RDTH84...
2020 Bobcat E42 R2 Series (A60462)
2020 Bobcat E42 R2...
