Dead auto darkening helmet
   / Dead auto darkening helmet #21
My helmet quit last week at a time when I had to weld something right then so I bought a new one from Snap-On he showed up about the same time.
Then later I fiddled around with the Miller and apparently the battery connections are touchy (odd ball battery anyway) because a slight tweak and its working again heck I don't know what to say except there may still be hope for yours?
Apparently the connections are touchy and not a great design. But I wired the battery to the terminals, checking to make sure I had 3v present. Nothing. So I'm assuming there is another failure. Guess I'll buy another and NOT store it in a bag, to make sure it is charged.
Going to do some searching here for suggestions.
Thanks,
   / Dead auto darkening helmet #23
If you weren't so far away I would say that I could take a look at it for you. There might be some other electronic geeks in your area that can look at that.
Well, I decided to take the helmet apart and see if I could find
another battery. I removed the headband and the inside and outside
shields. On a lark, I placed the battery in the slot while I was
holding the mask away from the workbench. I saw the mask go dark
twice. So I replaced the battery cover and held the on button and it
darkened. Took it outside and it is working again.
No idea what I did or if it was a random act. But it is good I tried again.
I follow-up to see if it keeps working. I did report the results to Miller. They haven't responded to my last few notes
   / Dead auto darkening helmet #25
Ah, yes, the old "I messed with it a lot, didn't really do anything and it started to work" trick.
Thanks for letting me know this happens to someone besides myself....glad it now is working again.
I hate it when that happens. I'm glad to have the helmet back, but I'd like to know what I did to fix it. First I want to know so I don't waste a lot of time when it happens again. Second, I wanted to post the fix here to share with others. That is one of the things I really like about TBN.
Looking back through this thread, it may be if the recommended cleaning and bending the contacts doesn't work, then the "mess with it" is the fix.
   / Dead auto darkening helmet #27
Hmm... maybe we should have a sticky thread..."I messed with it just before trashing it and..."
Last time this happened to me, I was convinced that the drill switch was fried, thus the drill dead and decided to salvage the cord. Discovered a pinch in the cord right at entry to the drill which caused wire to melt. Barely could see discoloration in black insulation. Cut out 3 inches of cord and all is properly screwy again:laughing:
   / Dead auto darkening helmet #28
Go back through the disassembly steps you took. Analyze each step in your mind and you will probably find that something was causing a contact to be maladjusted or a broken lead to make contact somewhere in that process and when you took things apart the contacts were re-established. Then again, maybe not.
Regardless, you need to have your shop sprayed for Gremlins.:rolleyes:
Happy to hear you are up and running again. Have the same helmet myself.
   / Dead auto darkening helmet #29
There ya go just like I said I did the other day strange how that happens isnt it!?
Glad yours is working and mine too except I now own a real expensive new helmet also toys toys toys never enough....:laughing:
   / Dead auto darkening helmet #30
It doesn't take very much corrosion or dirt to cause a malfunction with these low power circuits. The current draw is so minute that very little resistance (aka - dirt, corrosion) will essentailly open the battery circuit and make it appear that the electronics are no good. Mine has acted up a few times as well.
Steve
HEAVY DUTY QUICK ATTACH PALLET FORKS W/ 48" FORKS (A51244)
HEAVY DUTY QUICK...
2008 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51242)
2008 CATERPILLAR...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2015 Kia forte (A50324)
2015 Kia forte...
UNUSED FUTURE 10' X 7' CONTAINER (A51244)
UNUSED FUTURE 10'...
Craftsman YTS 3000 42in. Riding Mower (A49346)
Craftsman YTS 3000...
