Bob_Skurka
Super Member
- Joined
- Jul 1, 2003
- Messages
- 7,615
I use my tractors for a lot of different things, often times just transporting me and materials out to a spot on my property for a project, and I find I have projects scattered all over my property, some of them are located a few hundred feet away from the nearest power outlet. Has anyone installed a DC to AC Power Inverter so that you can plug in a standard electrical power pool such as a circular saw or a power drill for use on a field project?
I have a generator but it is too large to haul out to the field and is only used for emergency power backup purposes. I don't really want to buy a small 1500 to 2000 watt generator because that is just another engine to maintain.
I have a lot of battery powered tools, but often find them lacking even with extra batteries in a charger.
I thought that I might install a 1500 watt (3000 surge) power inverter on the tactor, probably directly wired to the battery. It would only be for occasional use so I am not worried too much about drawing down the battery. My compound miter saw and my circular saw each draw 15amps (1800 watts) on start up, my drills probably draw half of that. Realistically when I am building something the saw or drill run for only a few moments, then sit, then run, then sit a while longer. Battery drain should be virtually nil over the long run as long as the tractor's engine is running because there will actually be minimal draw by the inverter most of the time even when I am building something. And most projects in the field are repairs, or minor upgrades so I don't expect it would be a day long always on situation.
And from the prices I see, it would be cheaper than a compact generator by a couple hundred bucks.
Any thoughts on what problems this might cause?
