David Brown PTO output shaft broke! Sheesh...
   / David Brown PTO output shaft broke! Sheesh... #1
Slacker
Durham, NC
Farmtrac 360 TLB
While running the bush hog, the PTO output shaft (coming out of the rear diff) broke in half! It didn't strip the splines off, the thing actually broke in half. Shear pin in the bushhog didn't break....Tractor is a 1975 50HP and is a true Hoss. I've got to get this fixed....all my implements are cat 2 and my JD has a cat 1. Has anyone ever repaired a broken PTO output shaft? If it was welded up it would need the splines machined back in. I'm not sure where to look for the needed part. Brown tractors aren't that common in my neck of the woods.
Remind me to post pics this weekend.
   / David Brown PTO output shaft broke! Sheesh... #3
John,
I'm not sure, but I think he means the PTO shaft on the tractor itself broke.
   / David Brown PTO output shaft broke! Sheesh... #4
You should be able to get David Brown parts from a Case-IH dealer. Case bought out David Brown in the early '70's. I had a '76 990 and it had David Brown and Case on the hood. Got all my filters and parts from the Case dealer. The 990 DB was an excellent tractor.
   / David Brown PTO output shaft broke! Sheesh... #5
There is a section, I believe, at www.ytmag.com for David Brown. If my memory is faulty, the Case section talks about them. Should get some help there.
Funny how some hardened metal will crystalize, both rear axles on the IHC 300 broke off, known problem, just the wrong metal. Wonder if the same with your pto shaft.
--->Paul
   / David Brown PTO output shaft broke! Sheesh... #6
I believe Elmer is the resident David Brown expert in the Case forum. Shouldn't be a problem getting replacement parts.
   / David Brown PTO output shaft broke! Sheesh... #7
Yep, elmer is the DB expert if he is still over there on YTmag.
Ben
   / David Brown PTO output shaft broke! Sheesh... #9
When you post links by clicking on "URL", the first window that comes up is where you paste the link. The second window is where you name the link. Anything will work as long as it is shorter than the link. By doing it this way, a short link will be produced and the page won't be a doublewide. Thanks and this will help our readers and moderators.
Bumped for some pics of the carnage. **** bushhog shearpin didn't do its job....
2020 Chevrolet Tahoe SUV (A48082)
2020 Chevrolet...
1982 TANDEM AXLE CEMENT MIXING TRAILER (A50854)
1982 TANDEM AXLE...
2018 Chevrolet Tahoe 4x4 SUV (A50324)
2018 Chevrolet...
2017 Ram 5500 Valve Placer Bucket Truck with Versalift STP36NE - 41FT Working Height, Low Miles (A51039)
2017 Ram 5500...
2022 Club Car...
2014 Dodge Ram 3500 4x4 Crew Cab Pickup Truck (A48081)
2014 Dodge Ram...
