David brown 885
   / David brown 885 #1
kennyl123
Bronze Member
Pollock, LA
Ford 2000
Hey folks, I recently acquired a 1971 david brown 885 and steering had nearly a whole revolution of slack. I removed steering column and found the ball bearings worn out, I am in the process of rebuilding steering now. Upon inspection of gearbox cover I found that someone had cut the bottom of the steering reservoir with a torch It is not a machined cut, it is jagged and beaded. it is just above the transmission shaft. The manual says the reservoir has to be filled with oil before installing steering box because no way to access it after that. I suppose someone thought enough oil would sling from transmission to work. They also had it jam packed with grease and side cup under cross shaft. Now having said all that, my question is will the whole allow enough oil or do I need to replace the top cover. I have searched to no avail to find one but no luck yet. Any help would be great. Thanks Kenny
   / David brown 885 #2
There's no doubt that I would repair or replace that top cover, and seal it up as the factory intended.
2015 Club Car Golf Cart (A50324)
2015 Club Car Golf...
2015 Chrysler 200 (A50324)
2015 Chrysler 200...
E-Z Trail 675 Grain Cart (A50514)
E-Z Trail 675...
2018 WACKER NEUSON RD28 120 DOUBLE DRUM ROLLER (A51242)
2018 WACKER NEUSON...
UNUSED FUTURE MINI SKID STEER MOUNTING PLATE (A51244)
UNUSED FUTURE MINI...
