David Brown 885 oil seals
   / David Brown 885 oil seals #1
kennyl123
Pollock, LA
Ford 2000
hi all.... Upon removal of rear oil seal cover and driving seal out I discovered there were two seals pressed on top of each other . Is that correct? or did someone before me just installed wrong?
   / David Brown 885 oil seals #2
I used the Case/IH online parts book to look up the rear seal(s) on your tractor. Selecting the rear seal, #6 in the numerical list, it does say it requires 2 of the rope seals. Here is the link to it. Official Case IH Online Parts Store and Case IH Catalog for Best Parts Search and Best Parts Look Up. Case IH Parts for Case IH Tractors, Case IH Combines, Case IH Tractors, Case IH Manuals, Case IH Parts If the secondary window doesn't pop up, giving the description, part number, and how many required, just select #6 in the list.
You can even use the "check Price" feature, by selecting any near by Case/IH dealer,and it will show the price. Price should be good from any dealer in the continental U.S.
I thank you for looking this up but I was not clear on what seal I was talking about. I was talking about the rear axle seal that final drive shaft goes into rear end.
   / David Brown 885 oil seals #4
   / David Brown 885 oil seals #5
Hey Kennyl, curious to know if your final drive special tool problem has been sorted out. The subject was sort of dropped with questions unanswered. Hope you got the result you were looking for.
09112.....Yes, I managed to get it all lined back up and in place by hand, but let me tell you that was frustrating ....I'll never let that happen again if I need to pull the final drive out again. Thanks for asking
   / David Brown 885 oil seals #7
Great stuff. Glad everything came out as you wanted.
2019 FORD TRANSIT CONNECT CARGO VAN (A52577)
2019 FORD TRANSIT...
2003 FONTAINE TL50-NGB TRI AXLE RGN TRAILER (A52576)
2003 FONTAINE...
Landoll Hauloll (A53472)
Landoll Hauloll...
3/8 '' Wolverine Universal Quick Attach Cut Out Mount Plate (A51573)
3/8 '' Wolverine...
JOHN DEERE 4730 LOT NUMBER 268 (A53084)
JOHN DEERE 4730...
2007 Hino 268 Truck, VIN # 5PVNJ8JT072S50704 (A51572)
2007 Hino 268...
