David Brown 885 leaky sed. bowl
   / David Brown 885 leaky sed. bowl #1
drf64
Hi,
Newbie here with a DB 885 diesel. Bought the tractor 2 months ago and noticed a leak from the sediment bowl. I suspected the bowl and gasket were both at fault, but getting replacement parts has been a crap shoot. I ended up ordering 2 bowls. One appears to be the correct diameter but is too long. The other is too small in diameter by just a few mm. I finally decided to try replacing it last night and what a mess! First off, why is there no fuel shut off between the tank and the bowl???? Second, after I got the bowl off, it does, as I suspected, have a chip in the glass at the top which i suspect keeps it from sealing. Since neither of the new bowls fit, I replaced the gasket and tried installing the old bowl, but it still leaks. I even tried two gaskets, but it leaks.
Does any one know where I can get the correct bowl and gasket for this tractor?
Thanks, Dan.
Thanks!
   / David Brown 885 leaky sed. bowl #4
I know of at least 3 different fuel bowl sediment filters for the 885/995/1210 series, two different sizes of glass and one steel. You can always order the part from a dealer by your serial # and get the right one, but I have fixed the glass bowls before by cleaning the glass well with alcohol, and using some silicone caulk to fill in the chipped out area, waiting a few hours for it to dry, take a razor blade and cut it flat with the rest of the glass, and then putting it back on.
Good luck!
Good luck!
Thank you. I would like to try it. If I had a good way to shut off the fuel it would be earsier.
   / David Brown 885 leaky sed. bowl #8
50$ gets you the entire shebang.. .. me? i'd just be done with it and have a new lift pump and all.. :)
Very tempting. The only thing I need to be sure of is that this one is not the longer sized sed bowl. If it is, it won't clear the crankcase cap. I will call them tomorrow and ask about it. Thanks!
   / David Brown 885 leaky sed. bowl #10
good luck!
New Mahindra 8100 CLGC Euro Loader (A50774)
New Mahindra 8100...
2017 BOMAG BW145D SMOOTH DRUM ROLLER (A51242)
2017 BOMAG BW145D...
Parker 250 bu Gravity Wagon (A50515)
Parker 250 bu...
2010 MACK MRU613 GARBAGE TRUCK (A51243)
2010 MACK MRU613...
BEI MECHANICAL HARVESTERS (A51243)
BEI MECHANICAL...
2008 Ford F-350 Altec Service Truck (A50323)
2008 Ford F-350...
