Dashboard gauges sticking - anybody else hae this problem?
   / Dashboard gauges sticking - anybody else hae this problem? #11
4 screws, 2 plugs and your done. Its simple I promise
   / Dashboard gauges sticking - anybody else hae this problem? #12
Yes! Exactly same problem, with the same tractor, happening intermittently over a 3 year period, and last week found out why. Took the instrument panel out and disassembled, and found that the stop pins where the gauge needles rest when powered off, were covered with a tarry material that 'glued' the needle to the pin. Tried to clean the tar off, but difficult, so put a very small shrink sleeve (electronic wire type) over the pin, and all's well!! Evidently the gauges would work once the 'tar' got warm enough and/or vibration got big enough to release the needle(s).
Have fixed a few by taking apart and wiping with brake cleaner. Good idea with the shrink wrap! I think I'll try it next time!
   / Dashboard gauges sticking - anybody else hae this problem? #13
4035- tach sticks- tap it a few times and starts working. Today however I noticed that it came unstuck but wasn't reading correctly. Not sure what's up with that.
   / Dashboard gauges sticking - anybody else hae this problem? #14
Same story here, it works better when it is warm. This is really my only complaint with this tractor.
   / Dashboard gauges sticking - anybody else hae this problem? #15
I have the same problem with my 2009 Mahindra 4025 with the fuel gauge and temp gauge stuck on zero and the tach acting erratically. Not wanting to pay the price for a new Instrument Cluster I am tempted to try your fix. Were disassembly and re-assembly very difficult? Would appreciate any tips or suggestions on doing this.
   / Dashboard gauges sticking - anybody else hae this problem? #16
My 97 Jeep Cherokee still does that, hard smack on top of the dash fixes it. My 99 GMC Sierra also, same problem, same cure.
2024 AGT INDUSTRIAL HR-230 3-WHEEL LOADER (A51243)
2024 AGT...
2008 New Holland B110 MFWD Loader Backhoe (A52128)
2008 New Holland...
KUBOTA M7040 TRACTOR (A51406)
KUBOTA M7040...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52128)
REYNOLDS 100 - 8...
2018 Komatsu WA500-8 Articulated Wheel Loader (A50322)
2018 Komatsu...
2015 Volkswagen Passat 1.8T SE Sedan (A50324)
2015 Volkswagen...
