Dash replacement
   / Dash replacement #1
Zick
Platinum Member
WI
BX 2350
Mine's not needing replacement yet but was always curious about one thing. Does the hour meter hours transfer over or are you starting from zero again?
I also found after reading this thread 70 Series BX Dash in 60 Series? - OrangeTractorTalks - Everything Kubota that there is an updated cluster that is a different design and even comes w/ a wire adapter for different models.
I can't seem to find this bulletin they reference online.
Anyone done this yet?
   / Dash replacement #2
Unless the tractor has a computer with an internal memory driving the gauge you can probably expect a new gauge to start at zero. Make a note of your original hours when swapping gauges.
   / Dash replacement #3
Last time I needed a replacement meter it came with an adhesive label on which to write the hours on the old meter and attach it to the instrument panel. Not sure if Kubota is that way.
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A52748)
2006 Magnolia Dry...
2011 Ford Transit Connect Cargo Van (A50323)
2011 Ford Transit...
2011 Mazda 6 Sedan (A50324)
2011 Mazda 6 Sedan...
PENDING SELLER CONFIRMATIONS (A52576)
PENDING SELLER...
2017 Chevrolet Malibu Sedan (A50324)
2017 Chevrolet...
2011 Ford F-450 Crew Cab Omaha Service Truck (A50323)
2011 Ford F-450...
