CurlyDave
Elite Member
The first think I would try is to run a bolt into the hole from the back side. The threads there are not damaged and the bolt will easily follow the threads in and will push the distorted metal back into the right shape. This will cut the least amount of metal and will be the best repair you can get.
If you can not do that, a thread chaser from the front side is probably better than a tap. Again it cuts a smaller amount of metal.
If you end up having to buy both a thread chaser and a tap you are still way ahead of the game vs. replacing a hub.
