Damaged fan—ok to trim?
   / Damaged fan—ok to trim? #1
1428v
MF 1428v
Hi all, had a water pump fail and the fan wobbled & dig into the radiator and chewed up the leading edges. Anyone ever tried to trim the edges back instead of replacing the fan? Wondering how much that might affect the cooling. Thanks for your thoughts.
   / Damaged fan—ok to trim? #2
Penny wise, pound foolish? You surely can trim the plastic fan. Better yet, just toss it in the garbage. BUT - the fan is your first front to avoid overheating. Doing either would not be my advisce. For my nickel, I'd spring for a new fan blade.
   / Damaged fan—ok to trim? #3
I'd be more worried about balance than cooling.
   / Damaged fan—ok to trim? #4
i'd just replace the fan..... but it would need to be trimmed evenly on all blades.
you could try heating the damaged blades and straighten them
   / Damaged fan—ok to trim? #5
I had a similar situation with a plastic fan. The ends got chewed up about 3 years ago. I'm still running it today without any harmful effects.
It is hard to tell, but your metal fan looks bent? That might create an off balance situation which could do some long term damage.
2point2 beat me to it
Thanks all. Balance hadn’t even occurred to me. I’ll spring for a new one.
2017 Dodge Grand Caravan SE Van (A50324)
2017 Dodge Grand...
Alamo SH88 88" 3pt Flail Mower (A50774)
Alamo SH88 88" 3pt...
2018 Izuzu NPR (A50120)
2018 Izuzu NPR...
KJ 7'x20' Metal Gate (Deer) (A50121)
KJ 7'x20' Metal...
Pallet of PTO Shafts & Hydraulic Cylinders (A50121)
Pallet of PTO...
2016 Ford F-550 Palfinger PSC3216 4,000LB Crane Service Truck (A51692)
2016 Ford F-550...
