Damaged block installing block heater L5240
   / Damaged block installing block heater L5240 #111
I'm sure mine would start up just fine at any temperature I might even consider using a tractor at here in Wisconsin. Certainly down to -15, but... Using the block heater for 2-3 hours before I crank it just gives me a warm fuzzy feeling. It cranks easier, smokes less, and I'm sure the oil starts circulating faster. "Need" a block heater, maybe not. "Use" my block heater, oh yeah.
Yep, me too.
   / Damaged block installing block heater L5240 #112
Ditto.....old tractor did not have one but current one came with it and glad it did.
   / Damaged block installing block heater L5240 #113
All I have to say is..... bet you won't drill through a freeze plug again for a looooooooong time.
I don't know why anyone needs a block heater on a Kubota anyway unless you live in Alaska. None of my many had issue one starting here in Michigan in sub zero weather...ever.
Installed one in mine this past fall after purchasing the tractor. I used it to move snow last weekend. It was 14 degrees out so I plugged her in for around 45 minutes...started like it was 70* out! Sure it isn't needed but there's more wear on any engine when it's started in cold weather. For "short money" it's worth it in my opinion.
   / Damaged block installing block heater L5240 #114
My new L6060 sure DOES NOT like the cold. The auto glow plug control really stinks. 10 degrees out and the glow plugs only light up for 2 seconds, give me a break. Put the glow plugs on the key switch like they always used to be. I don't want to have to crank the engine over 6 times at 15 seconds each to get it to fire up.
I do have a block heater and I'm really glad I forced the dealer to install it. They said it wasn't needed and they never sell them.
Well they have now...
I have to say I have been keeping tabs on this thread and I am impressed with the OP's cool. I can't imagine what my temperament would be like if I were to have done this.
   / Damaged block installing block heater L5240 #115
I'm with you. I don't like that knocking sound of a cold diesel (the engine or my heart!). :p
   / Damaged block installing block heater L5240 #116
When you do enough things in life, you will eventually make tons of mistakes. You learn over time that what gets broke can be fixed, so after the initial cursing is done, you get your head together and figure out how to fix it. It comes with experience. One of my favorite sayings "Good judgement comes from experience. Experience comes from bad judgement"
And I agree on the block heater points - it makes starting easier and less stressful on the engine. I have one in my truck which has lived outside until last week when I finally got my kitchen island cabinets installed, thus freeing up a stall for the truck. It was always happier starting after plugging it in in the dead of winter.
   / Damaged block installing block heater L5240 #117
I hate that too. I had a cylinder liner let loose of the parent metal in cold weather once and end up in the crankshaft. I think it was improperly sized by the previous owner upon rebuild, but I still never forget it when I start a cold engine.
   / Damaged block installing block heater L5240 #118
I'm sure I'm a lot older than the OP and when I was younger and screwed something up...a few "F Bombs" were always launched, but then you have to stop and assess the problem and not be afraid to ask others with experience for help. I always told my son and daughter growing up..."It's OK to make mistakes, as long as you learn from them and don't make them a habit!" Let's face it, if you're handy and have common sense, it's likely you do a lot of your own work. It's going to happen...you're gonna ****-up... and in the end you'll be SMARTER for it. Looking back I think a quarter of the tools I own were purchased to fix screw-ups!!! :laughing:
OP you're taking the right approach. Take the time to fix the problem RIGHT the first time! The last thing you want is a half-assed repair that when fails no-one else wants to touch!!!
Yup, at this point, slow and steady is going to fix the problem. If the block is trash, I'll buy a new block. It's that simple. My only bad habits are Tractors and Hunting.
Tractor has 850 hours on it and I just payed $22,000 for it in August to avoid Tier 4 on the new ones.. Yeah, it's worth it.
   / Damaged block installing block heater L5240 #120
Good habits. Mine too plus motorcycles.
If I had to replace one of my tractors I'd also look for used no tier 4.
Very best of luck to you on fixing this.
2860 (A56857)
2860 (A56857)
Kubota M125X (A60462)
V.E. ENTERPRISES 500 BBL FRAC TANK (A58214)
V.E. ENTERPRISES...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A56438)
2006 Magnolia Dry...
2001 CATERPILLAR 621F MOTOR SCRAPER (A60429)
2001 CATERPILLAR...
2002 TOYOTA 7FDKU40 FORKLIFT (A57880)
2002 TOYOTA...
