Daihatsu Mini-Truck
   / Daihatsu Mini-Truck #11
Here's what I found:
Ours is a Suzuki 5 speed manual 4 wd with locking rear, right hand drive.
The truck will do about 45 mph with a stiff tailwind. Not enough hp or torque to climb hills on-road as it quickly looses momentum and you have to downshift to 3rd to climb any hills. Not sure what it would do loaded, as we leave the bed empty and load what we need from other fire apparatus when we get there.
The truck is so nose heavy that if you try to come downhill on a steep slope it lifts the rear wheels. We had ff's ride in the back to hold it down, but I was concerned for their safety as we were on a skidder road and the ground was very rough. I opted to have them climb out and do the ride-the-front-bumper thing.
As far as climbing, it spun out very easy. I tried it in L gear (ours has a creeper, but no low range) and locked in the hubs. Even with 2 guys in the cab there is no way it would make it. As soon as the ground got uneven it spun and as soon as that happened all forward momentum stopped. I've done a lot of wheeling on and off road, driven everything with wheels, and really was disapointed with it's climbing ability.
Load carrying is limited. When we did load it down with stuff (Indian tanks, hose, pumps, gear, drinking water totaling maybe 6-800 lbs) it wanted to burn the clutch on the steep parts. May have been a clutch issue, as I sent it out and they put a new one in it, but didn't seem to be able to pull or haul much when loaded.
Stability is better than I expected. Even when on its nose it really did ok. I was impressed with that. It felt like it was going to go over numerous times, and only a couple times we had to have fire fighters grab it and hold it from rolling over. Admitedly, we were in a very rough, very steep area. Certainly nothing a pick-up would go in. I suspect, and my father likewise agreed, a Willeys Jeep would have been much better suited for what we were doing.
Ground clearance was an issue. The pan under the tranny hooked up on a couple stumps (we were in ferns and weeds, so objects in the trail were hard to spot). The tranny plate was slightly bent when we finished and the underside had dragged across numerous rocks, but nothing was badly damaged. The antenae did get broken off from low hanging branches.:eek:
The other times I have used it, it worked great for minor off road stuff where a decent trail is present. It's not an atv and not a jeep, but for an enclosed vehicle to run bales of hay around for feed or to fix fence, probably would be handy. I will say, I'm 5 11 and 250 and the cab is tight. Not easy to get in and out of.
All in all, if I had my way I'd sell it and get a Big Boss 6x6 or a Polaris Ranger (we had both at the fire and they all made it where the Suzuki had to winch itself). I'm only second in command, so I can't get rid of it. JMHO
Here's a few pics, of course only one has a glimpse of the truck. I was more interested in the chopper than the truck, sorry.
   / Daihatsu Mini-Truck #12
To what do you attribute the limitations? Not a low enough 1st gear? Too
much front weight bias? What?
You and DARGO have experience with these micro-trucks off road...I do not.
Do tell.
(BTW, I had to Google Joey--Joie Chitwood.)
I think the previous post sums it up well. It fits with what I experienced. That is why I said they'd be okay on a flat dry ranch for light duties. It wouldn't handle even close to half the weight my Kubota RTV900 would and it did poorly off road. I think mine would run a little faster on the road, but it too really suffered from low power when going up hills on the road and I had to downshift even when empty. If they won't do what you want with no modifications, it would be cheaper (believe it or not) to just buy a Gator or RTV to start with. Even with numerous and expensive modifications it will still fall far short of the others if used much. Remember that taller more aggressive tires will gear it up and make it feel like it has even less power. I was happy to only lose $500 when I dumped mine. They are really hard to sell. A lot of people looked at it but it seemed nobody wanted it.
   / Daihatsu Mini-Truck #13
This link will take you to All Terrain Mini Trucks, and a specification chart comparing the following: Mini Trucks, JD Gator, Cub Cadet, Kawasaki Mule, Kubota RTV900
Compare - Japanese Kei Mini Trucks To Standard Utility Vehicles
I'm glad I found this because I was confused, and thought the payload capacity of these mini - trucks was only 600 lbs., which is puny, but that is the cab capacity. Whereas the payload is actually 1200 - 1500 lbs.
Now, I just may reconsider, as I see it will be more feasible to move larger loads of shale, and soils with one of these rigs. The beds are approximately 4 yards.
Um, that "comparison" will mislead you at best. I had a direct comparison to the RTV myself. That "comparison" takes a very, very generous view of the mini-truck. I assure you that if you go by that for a buying decision, you'll regret it. If I put 4 yards of dirt on a mini-truck, it will be ready for the scrap heap. That amount of my wet heavy clay soil would weigh well over 10,000 pounds. My RTV hauled and dumped hundreds of 2000+ pound loads. I have pictures of that on here. The mini-truck really can't handle half that and wouldn't even dump what it did haul.
As I said before, they are okay for what they are. They just really won't compete well with a work designed side by side. I'd really suggest avoiding any dealer who claims they will. They don't seem too honest based on my actual experience with the trucks.
   / Daihatsu Mini-Truck #14
As Dargo said, it puts alot of favor to the mini-truck. Also, the comparison isn't the most accurate, it lists the RTV as a gas utv. Gotta look at and know your opponents to truly compare.
Kyle
   / Daihatsu Mini-Truck #15
I have had a mitsubushi truck for about 8 months. I love it! It has gone anywhere I wanted it to go. I have a 2 inch lift with atv tires on it. I have really enjoyed it the last couple of months when the temps have been cold the heater is really nice. As far as speed it will run up to 60-65 mph and gets between 35-40 mpg. I have even loaded my welder (miller bobcat) cutting torch, and all of the assc. items for welding and used it to weld around the place. In Oklahoma they just made them legal on certain roads but don't know the details yet. I think for the money you can't beat them on the farm they even make a little cake feeder for the back of them to feed cattle out of.
   / Daihatsu Mini-Truck #16
I've had a Diahatsu hi-jet for 2 years now. It'll do 75 wound out on the highway, gets 40 miles to the gallon if you keep it at 55mph. In 2 years I've put 22000 miles on it and the only repair has been to replace the alternator belt. I use it on the farm alongside a '07 gator hpx. I've had over a ton of feed on it and it did squat a little, but has toted that much many times. It's not quite as good in a mudhole as the gator, but will go further than most full size 4x4 trucks. It cost half as much as the gator and will do 99% as much and doesn't use as much gas to do it. They are great little trucks.
   / Daihatsu Mini-Truck #17
I have a daihatsu hijet and I usually carry 2000lbs .it has a3inch lift with Afco 275lb springs. I also run14inch mudders. The top speed is 86mph and it will go anywhere.
2006 Ford F-150 XLT (A44501)
2006 Ford F-150...
2014 Schwing SP 500 Concrete Pump (A42203)
2014 Schwing SP...
John Deere 5090E (A44501)
John Deere 5090E...
2019 FORD F-250 SERVICE TRUCK(INOPERABLE) (A45046)
2019 FORD F-250...
24ft x 28ft Metal Building (A44391)
24ft x 28ft Metal...
AIRMAN COMPRESSOR (A45046)
AIRMAN COMPRESSOR...
