Daewoo Skid Steer Blowing Hyd. Filter Gasket
   / Daewoo Skid Steer Blowing Hyd. Filter Gasket #1
HHR
Platinum Member
Northern MN
1997 Daewoo Dsl 801
We have a 1997 Daweoo DSL801 skid steer loader with around 1800 hours on it. Over the past year or so, the hydraulic warning light would come on randomly. Today, under very light usage, the hydraulic system emptied itself by blowing out the filter gasket and completely covering the engine compartment with oil.
The filter was changed last fall (NAPA 1202), but the intermittent light issue was present before the filter change.
Any ideas? Is there some type of relief valve that could be sticking?
   / Daewoo Skid Steer Blowing Hyd. Filter Gasket #2
Are these spin-on type filters or cartridge type? Either way I would suspect some down stream restriction is causing excessive back pressure which would cause the seals to fail. Does the outlet of this filter feed into an oil cooler?
It is a spin-on filter with a tapered seal that fits the tapered seat on the housing perfectly.
I am not positive, but I believe that the outlet on the housing branches off and goes back to the cooler and forward to some type of junction block.
Here is a photo taken from the rear of the machine showing the filter setup:
2014 KOMATSU HM300-3 OFF ROAD DUMP TRUCK (A52705)
2014 KOMATSU...
2015 Vermeer SC362 Stump Grinder with 2018 S/A Flatbed Trailer (A53421)
2015 Vermeer SC362...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
New JMR 40" Skidloader Grapple (A50775)
New JMR 40"...
2017 Nissan Versa SV Sedan (A53424)
2017 Nissan Versa...
2020 Nissan Rogue SUV (A51694)
2020 Nissan Rogue...
