Daedong EX45 HST
/ Daedong EX45 HST #1
laarsen
Bendigo, Vic.
Daedong EX45HST
G'day,
This is my first posting, I hope someone can help.
I own a Daedong EX45HST tractor. I understand that these tractors are sold in the USA as "Kioti" but the specs and mechanicals are similar. My tractor has a hydrostatic transmission. There is a so called "Cruise Control" which keeps the hydrostatic forward pedal at a preset position with an electromagnet on the side of the pedal under the floor board. The problem is that the magnet does not appear strong enough to hold the pedal at the full forward position.
Has anyone had this issue with their tractor or does anyone know of a modification to remedy this problem?
/ Daedong EX45 HST #2
Check the voltage at the electromagnet and make sure it has good grounds/connections.
/ Daedong EX45 HST
G'day Carpenter 383,
Hello to you from Australia and thanks for your advice.
I think I have solved the problem with the cruise control. I have removed the forward pedal and cleaned off all the paint where it comes in contact with the magnet and I have realigned the magnet so it makes contact with the pedal with minimum clearance. It is working well now. It is a very good tractor and I am extremely happy with its performance.
cheers, John :)
/ Daedong EX45 HST #4
Glad you fixed the problem and welcome to tbn!
Crane (A64194)
Crane (A64194)
New/Unused CFG Industrial H12R Mini Excavator (A65583)
New/Unused CFG...
2004 CAT 247B SKID STEER (INOPERABLE) (A65643)
2004 CAT 247B SKID...
New 2x27 Ratchet Strap (A65583)
New 2x27 Ratchet...
2019 FORD F-550 SUPER DUTY (A65643)
2019 FORD F-550...
86 (A63290)
86 (A63290)
