Oil & Fuel D414 leaking oil out of exhaust
   / D414 leaking oil out of exhaust #1
farmallboy1980
Gleason, WI
International
Hey everyone. I just put an inframe kit (piostons, rings, sleeves, bearings) in my D414 and had a shop grind valves, put new injector tubes and surface the head. I put about 10 hours on it and all of the sudden it started to run a little rough, lose a little power and throw considerably more greyish black smoke out the exhast. I had about 70 psi oil pressure and the temperature did not get above half (which is how this tractor has always run). I drove it across the field and parked it and there is a pretty good amount of engine oil leaking out of the exhaust manifold where the muffler attaches. Anyone have an idea of what is going on??? I would imagine that the new head gasket blew but am not sure? There is little to no blow by out of the tube. All ideas are appreciated!!
Tom
   / D414 leaking oil out of exhaust #2
Are you sure it is engine oil, or blackened raw fuel. I had an injector go bad on my MF 180, and when I saw what I thought was engine oil, was actually raw fuel, blackened by carbon out of the manifold.
   / D414 leaking oil out of exhaust #3
Change the thermostat, block part of the radiator, do whatever you need to do to get the coolant temp up to an actual 180-200 degrees F and run the crap out of it for 10-20 hours. You are trying real hard to glaze the cylinder walls and are doing nothing to get the new piston rings to seat.
You are heading down the road to killing a fresh overhaul with kindness.
1998 Club Car Electric Cart (A56859)
1998 Club Car...
UNUSED FUTURE 12" HYD AUGER (A52706)
UNUSED FUTURE 12"...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
Milwaukee Red Zone Tin Sign (A57454)
Milwaukee Red Zone...
78in Quick Attach Smooth Bucket (A57453)
78in Quick Attach...
Pickup Truck (A59230)
