D31 Track Tension
/ D31 Track Tension #1
powellj5
I own a 1989 Komatsu D31A dozer. I am not able to tighten the left track. The grease cylinder seems like it is locked up or something - it just won't budge no matter how hard I pump my grease gun.
I've taken the guard off and I don't see any grease leaking or anything. I've changed the grease plug and it still won't accept grease.
Any ideas about how I can fix this problem?
/ D31 Track Tension #2
About the only thing you can try is to clean the chrome ram bar of any dirt or rust . Remove the grease nipple/Zerk holder so the grease can be expelled . Put a lump of hardwood between the sprocket top and the track chain and reverse the tractor a foot . If the ram wont retract and free up by doing this , I'm afraid you will have to dismantle the whole thing and reseal it . Moisture gets into the end of the ram and jambs it up . Just be careful when doing as i suggest , if the ram does not retract , the recoil spring will and it will be under a lot of tension .
/ D31 Track Tension
I'll give it a try. Thanks for the advice.
/ D31 Track Tension #4
Can you lift the idlers off of the ground with the blade, and taking some pressure off of them? What happens when you remove the zirk fitting? Does grease come out? Have you tried replacing the zirk fitting with a new one? or is that what you call the grease plug?
Eddie
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
2016 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2005 LEDWELL LW40ADC - 40' ALUMINUM FEED TRAILER (A63290)
2005 LEDWELL...
2000 Belshe dt-255 Trailer (A64194)
2000 Belshe dt-255...
2021 CATERPILLAR 299D3 XE SKID STEER (A65053)
2021 CATERPILLAR...
